Need a dimension - original steering column
Old Sep 3, 2011 | 04:20 PM
turnrjr's Avatar
turnrjr
I'm keeping the stock steering column and steering wheel. I have a plan to mate it to the toyota PS box and keep my column shifter. When I cut it I want to make sure the steering wheel stays where it belongs. I need a measurement from a stock 53-55 F100 steering setup. The length measured along the steering column between the column support clamp and the underside of the "bell" at the top of the column. I appreciate the help.
Bob
Old Sep 3, 2011 | 04:39 PM
Marty Smilt's Avatar
Marty Smilt
What year truck?????
Old Sep 3, 2011 | 05:13 PM
John Wiseman's Avatar
John Wiseman
On the right track
i have heard of people using a toyota ps box . my dad did ps on his 56 he also used the front clip out of a plymouth volare wierd crazy welding if you have bottomless pockets like what we see on tv anythings possible.
Old Sep 3, 2011 | 09:06 PM
1oldtimer's Avatar
1oldtimer
I have a '56 column in mine so it will be shorter. Don't forget a good floor mount as the column drop alone won't hold it steady with a u joint. I fixed my column in my '54.
https://www.ford-trucks.com/forums/9...mn-repair.html
Old Sep 3, 2011 | 10:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Can't help with the dimensions, but I'd have a hard time believing the longer Toy box can be used and still keep the column shifter (manual trans, I assume?). Unless it's mounted higher on the '54 column than on BonusBuilts.
Old Sep 4, 2011 | 12:44 AM
1oldtimer's Avatar
1oldtimer
Good point, I missed that part. I don't think there's enough room for the stock column shifter, here's my '54 from the firewall to the box.
Old Sep 4, 2011 | 06:46 AM
turnrjr's Avatar
turnrjr
My truck is a 54 body on a 56 frame. Yes it's tight where the column shift arm linkage is mounted at the bottom of the column but it has been done.
Rodding Roundtable :: View topic - Column shift on a F100 power steering conversion
Oldtimer, I am supporting the bottom of the column from the inside but I can't use the nice aftermarket one because the shift tube would hit it. I saved an article from Classic Trucks magazine where they made a new heavier floor plate like you did. MIG welded a short piece of tubing to it at the right column angle. The column goes through it and is clamped.
ALBUQ, once the column is fitted I will be shortening / rebuilding the shift tube using your tech article. I am having trouble finding a new cross pin.
Thank you guys.
How about that dimension? Anybody?
Old Sep 5, 2011 | 12:43 PM
abe's Avatar
abe
I just measured mine. It is 12" from the clamp to the bell under the wheel.
Old Sep 5, 2011 | 01:26 PM
turnrjr's Avatar
turnrjr
Thanks Abe I appreciate your help.
Darrellt
May 22, 2017 12:57 PM
Grinchman
Dec 27, 2015 07:38 PM
robramsey
Mar 3, 2013 04:18 PM
My9fam
Dec 16, 2012 10:42 AM
e william
Feb 26, 2004 10:31 AM
