"Field Service Action: Oil Pressure"
#32
#33
I thought the frame support issue was Gas motors only, that shows on the diesel VIN if that is indeed the truck.
EDIT:
ETIS Truck info
Build Date: 12.09.2016
Vehicle Line: F-Series Super Duty
Body Style: Double Cab (3/4 Door)
Version: 350 Series
Engine: 6.7L 4V V8 T/C Diesel
Transmission: 6 Speed Auto Trans (6R140)
Drive: LHD 4WD (PTD)
Axle Ratio: 3.55
Emission: 50 State Emission Requirements
Air Conditioning: High Capacity Air Conditioner
Territory: (+)"USA"
Paint: Ingot Silver Metallic 2
EDIT:
ETIS Truck info
Version: 350 Series
Axle Ratio: 3.55
Territory: (+)"USA"
It was a September 12 2016 build. Great! I hope this doesn't include early December builds. It's amazing what we can find doing a little detective work 😉
#34
OK, to add a little levity to this thread, I contacted someone in the know at Ford and got the following response on this issue. Initially I thought it was off the record but he gave me permission to share it here with you fine folks. He also said he'd drop in and clear up any additional questions if needed. So, no stop ship at all. Just a pre delivery test...
"It's real, but very exaggerated by the video floating around and the forum threads.
Right now it's a standard demonstration/delivery hold. The bulletin is posted up on Ford's internal website for dealers. It's a simple scan with IDS at startup that the tech must check. If the truck passes the test, it's ready to sell and no repairs are required. If it fails the test, the dealer is to hold it until parts and repair procedures are released, due mid January.
Here's the kicker.... Ford is currently estimating about 1% of trucks are affected. So it's not a widespread problem. I'm certain that a few people will take this and run as if all trucks are now a disaster waiting to happen.
Basically it's the engine oil pump that is the culprit. The test checks the oil pressure at startup, as the OIL_LOW_SW PID must change from "low" to "not low" in less than 3.25 seconds. If the oil pump can't get the pressure up within that time, it leaves the engine vulnerable to catastrophic damage and low-mileage failure."
Speaking of Curtis... scroll down...
#35
Just to clear the air on this topic.
Yes there is a field service bulletin out to all the dealers regarding engine oil pressures on 2017 6.7L PowerStrokes. Dealers are to perform an inspection of all unsold trucks. If the truck fails inspection, the dealer is to hold it until a fix is released - due mid January.
The bulletin also states that less than 1% of trucks are expected to be affected and require repair. The rest are fine.
Being that this affects such a small percentage of trucks suggests that this is not a widespread problem, and shouldn't be a concern for owners. Demonstration/delivery holds happen all the time. Ford is aware of an issue and will have a solution in the coming weeks for those trucks that are affected.
#38
#40
#41
#42
#43
#44
Not sure which site he was using Scott. Someone will post it shortly I'm sure or you could shoot him a PM...
