ABS or Not
First off happy Christmas and new year. Now down to the question in hand. I have a 2001 f350 4x4 with7.3 diesel...I have recently noticed a low grind like noise coming from the right front. I have troubled shot the issue and I am 100% sure it is the wheel hub assembly. Did I mention I am running 37x13.50 tires..and now you are says no no **** it is the hubs...and they are the original hubs..lmao..my question is every thing I look for shows ABS is on my truck... I look at the hub and don't see it.. so with the Dana 60 front does it have ABS or not? Also, should I go motorcraft, Timken or moog wheel hubs? Also, anyone know where I can get at a decent price?
My axle is missing the sensor on the passenger side, so I have an ABS fault. The drivers side is present. The wire comes down and along the axle tucked in to the hub behind the break rotor.
