Sponsored by: Real Truck
abs brakes
Old Nov 14, 2006 | 02:12 PM
mrpaintman's Avatar
mrpaintman
abs brakes
I tried to order a new set of slotted rotors(front) but they need to know if my truck has rear only or 4 wheel abs, how do I determine this?
Old Nov 14, 2006 | 02:13 PM
mrpaintman's Avatar
mrpaintman
ps I have a 2000 f250 sd diesel ext cab4x4
Old Nov 14, 2006 | 03:09 PM
Pocket's Avatar
Pocket
A quick look at the front hub assembly will tell you. If you see an electrical connector going to the top of the hub assembly just above the caliper, then you have 4 wheel ABS.
Technically our 4 wheel abs works with front left and right abs sensors, and a single rear axle sensor.
