Glass Pack Exausht
Old Dec 23, 2001 | 02:26 PM
EaSTxCOwboY's Avatar
EaSTxCOwboY
Glass Pack Exausht
Aight guys and gals yet another ? in the world of FORD (#1). I am looking to Stick Glasspacks on my truck. I want to run pipe from the hedders to the seperate glasspack mufflers then straight on back to the echo tips. I thought if i did this it would burn up my exausht valves. Does anyone have any input it would be greatly appreciated
Old Dec 23, 2001 | 04:52 PM
Pastmaster's Avatar
Pastmaster
Glass Pack Exausht
I'm guessing what your saying is that you allready have dual exhuast after the convertor, and you want to make it true duals?
If that is the case then yes, it CAN be done. First off, do you have emissions tests where you live? If not, then you can do it. You can run new pipes from the exhuast manifolds to where the Y-pipe is at on your current system.
If you run mufflers then no, you will have enough backpressure to keep from "sucking" a valve.
'93 F-150 loaded and modified!
http://briefcase.yahoo.com/toydestroyer1
Old Dec 23, 2001 | 04:58 PM
EaSTxCOwboY
Glass Pack Exausht
ToyDestroyer u didnt get what i was saying. I am going to go from the original hedders and go STRAIGHT back to dual glass pack mufflers. Each pipe will have its own glass pack muffler. they will not be connected in any way. and then going back to echo tips. now tell me will i burn up my exausht valves?
Old Dec 24, 2001 | 09:54 AM
ranger78's Avatar
ranger78
Glass Pack Exausht
in my 96 f150 i put hedders from a 79 mustang on and from there went pipes back to glass packs back to echo chambers, it has been like this for about 20,000 miles and no problems yet. i hope this helps.
Old Dec 24, 2001 | 11:01 AM
FordMan77's Avatar
FordMan77
Glass Pack Exausht
rheal
6.4L Power Stroke Diesel
38
Oct 10, 2012 08:13 AM
BAD351W
Exhaust Systems
26
Mar 30, 2009 10:05 PM
MXZX1100cc
Modular V10 (6.8l)
Feb 11, 2008 04:01 PM
jonezy.de61
1983 - 2012 Ranger & B-Series
25
Sep 20, 2006 07:42 PM
EaSTxCOwboY
Jan 30, 2002 09:11 AM
