Sponsored by: Auxito
Ball joints
Old Dec 24, 2016 | 03:59 AM
sam hain's Avatar
sam hain
Ball joints
Looking to replace upper and lower ball joints in my truck, but after checking Rock auto and Napa online both only show options for upper that say "will not fit OE control arm". Do I have to buy a whole new upper arm?
Old Dec 24, 2016 | 11:42 AM
blupupher's Avatar
blupupher
Yes, you need the entire upper control arm. The OEM upper has a non-replaceable ball joint. No idea why.
Kind of a pain, but you end up with new upper bushings as well.
Old Dec 25, 2016 | 09:00 AM
steve(ill)'s Avatar
steve(ill)
Do yourself a favor and buy MOOG for at least the bottom joint... MOOG are not that much more for the complete top either.
Old Jan 1, 2017 | 09:31 AM
SteevenH's Avatar
SteevenH
Replace the upper and put a new ball joint in lower. I to recommend Moog.
Old May 22, 2025 | 07:47 AM
Evan76's Avatar
Evan76
I read somewhere that ipper joint couldn't be changed. Noticex when i did put my new control arms on tgat the ball can be changed.
definitely put some new shocks on while you have them out to change arms
Old May 22, 2025 | 09:23 PM
Sandstar's Avatar
Sandstar
4th Gear
Junior member
[QUOTE=sam hain;16815611]Looking to replace upper and lower ball joints in my truck, but after checking Rock auto and Napa online both only show options for upper that say "will not fit OE control arm". Do I have to buy a whole new upper arm?[/QUO
Old May 22, 2025 | 09:28 PM
Sandstar's Avatar
Sandstar
4th Gear
Junior member
yes Sir you will. And that's how I found out why there is I price increase in the upper and lower ball joints because I just went through that.
Old May 23, 2025 | 08:14 AM
manicmechanic007's Avatar
manicmechanic007
Search around, you can get a ball joint kit with two arms and a set of lower ball joints cheap on Ebay.
Moog is decent, but I also use the cheap China parts with good luck too
Old May 23, 2025 | 11:39 PM
Sandstar's Avatar
Sandstar
4th Gear
Junior member
Thank you Sir for answering my call. I hope you had a good day.
joeltwise
1997 - 2003 F150
Jun 21, 2009 09:37 PM
stang3O2
1997 - 2003 F150
Feb 25, 2009 09:39 PM
bowdog
1997 - 2003 F150
Sep 2, 2008 09:19 PM
mattadams
Aug 12, 2004 08:36 PM
shinew
Mar 7, 2004 10:06 AM
