Sponsored by: Auxito
New Ball Joints
Old Aug 31, 2008 | 09:47 AM
bowdog's Avatar
bowdog
Question New Ball Joints
I am getting ready to buy new lower Ball Joints for my truck. They have begun to sqeak but are not wore out yet. There is no play in the joint yet but they are sqeaking.
My question is ......Do I have to buy the whole control arm with the ball joint already pressed in or can I just get the joints? What are the dis-advantages and advantages of doing this?
Secondly. should I get motorcraft or are the aftermarket ball joints just as good? What are the cost of motorcraft balljoints?
Help me make the right decision.
Bowdog
Old Aug 31, 2008 | 12:14 PM
Bobby82490's Avatar
Bobby82490
No you dont buy a new lower control arm.. only the upper control arm needs to be replaced with the ball joint.
Advantages- Cheaper by about $75 per side(lower ball joint with lower control arm-$105, just lower ball joint-$30)
Disadvantages- Need to rent tool to press lower ball joints into lower control arm, a little more time consuming.
I would buy Moog joints, they are good quality and are regreaseable.
Old Aug 31, 2008 | 12:17 PM
AzBlueWolf's Avatar
AzBlueWolf
I second Moog!
I put new moog joints on my truck 3 years ago...no problems whatsoever!
Take your time and be careful!
Old Sep 1, 2008 | 10:04 PM
forder1000's Avatar
forder1000
I ran into a problem where the ball joint,( tried genuine ford, motor craft and another after market brand ) and the ball joint was to small for the control arm hole. Don't know if it was wrong control arm installed on truck when assembled still tryibng to figure it out
Old Sep 1, 2008 | 10:08 PM
AzBlueWolf's Avatar
AzBlueWolf
maybe try a newer year, or an older check your manufacture date
someone may have replaced the control arm with a used one
take the old ball joint with you to the autoparts store
Old Sep 2, 2008 | 09:17 PM
fordmerc's Avatar
fordmerc
I also say get the moog joints, and while you are under there, replace the sway bar links too with moog, since the stock ones tend to break. Check out Discount Auto Parts they have pretty good prices.
Old Sep 2, 2008 | 09:19 PM
fordmerc's Avatar
fordmerc
oh and if you buy the moog upper joint and control arm, that ball joint can be pressed in and out unlike the stock ones, so if you have to replace them again, you don't have to get an alignment.
