Lower Ball Joints
Old Mar 6, 2004 | 08:58 PM
shinew's Avatar
shinew
Question Lower Ball Joints
I was advised my lower ball joints on my 98 Expedition need replaced for state inspection. I looked in the repair manual and it says that the joints are a part of the arm and cannot be replaced. Yet, the auto parts stores will sell me the lower ball joints. So............can you replace the lower ball joints or must you replace the entire arm? It look to me you can "press" out and replace the ball joints.
Old Mar 7, 2004 | 12:45 AM
Racerguy's Avatar
Racerguy
Yes they can be replaced without replacing the whole control arm.
Just replacing the ball joint is a lot easier than replacing the whole arm too.
Old Mar 7, 2004 | 09:21 AM
shinew's Avatar
shinew
Thanks Racerguy..........its looked like they were replacable. One more question, do they in fact need to be "pressed" out.....or can they be removed/installed without a mechanical press?
Thanks. Bill
Old Mar 7, 2004 | 10:06 AM
Racerguy's Avatar
Racerguy
At work we have drivers for them but normally you use a ball joint press which looks like a big C-clamp with a receiver cup to fit over the joint. Some parts stores will rent these to you.
sam hain
1997 - 2003 F150
May 23, 2025 11:39 PM
Marty1965
1997 - 2003 F150
Sep 8, 2016 05:16 PM
boosteddsm
Jun 15, 2011 09:44 PM
elk
Mar 18, 2005 09:06 AM
martiniaz
Feb 13, 2003 08:10 PM
