windshield washer issues
Old Dec 23, 2016 | 09:47 PM
cornstar6207's Avatar
cornstar6207
I have a 2004 Super Duty with a 6.0 diesel. Recently the windshield washer seems to have lost some of it's spray power. It still sprays, just not very hard. I know it's not frozen, as it started this before it got cold. Any ideas? Any and all replies are much appreciated!
Old Dec 23, 2016 | 11:14 PM
Yahiko's Avatar
Yahiko
Does it look like the stream has gotten heavier?
I had to replace both nozzles right after I got mine in 2012
because one was blown out and was more like a garden hose.
I did both but only the one was bad.
Place you finger over the nozzle and see it the other one sprays better
and then switch and check the other side.
Old Dec 24, 2016 | 05:21 AM
duste's Avatar
duste
You may have some dirt inside the nozzle, take the hose off under the hood and blow air in through the nozzles itself . Don't blow into the hose side, if there is dirt it'll make is worse. Reconnect and try them again. I have to do this every now and again to one of my trucks.
Old Dec 24, 2016 | 10:51 AM
jmaskew's Avatar
jmaskew
Another thing to check is remove the bottle then remove the little pump. There is a screen on the end of it that gets plugged up. I had a jelly like substance blocking mine a few years back.
bigboylk
1978 - 1996 Big Bronco
Dec 23, 2017 03:48 PM
johnbeaver
Jun 19, 2017 10:47 PM
Doc
Oct 18, 2011 08:05 AM
Will_01_GT
Feb 17, 2007 10:06 AM
LonghornOwner
May 5, 2005 06:46 PM
