hpop---???
Old Dec 23, 2016 | 06:50 AM
1bigjoe's Avatar
1bigjoe
Old Dec 23, 2016 | 06:51 AM
1bigjoe's Avatar
1bigjoe
Old Dec 23, 2016 | 06:52 AM
1bigjoe's Avatar
1bigjoe
Old Dec 23, 2016 | 06:53 AM
1bigjoe's Avatar
1bigjoe
Old Dec 23, 2016 | 10:10 AM
knottyrope's Avatar
knottyrope
Originally Posted by fordman67
Huh? Not even close. Bad bad bad info.
The IPR let's oil return to the oil pan to regulate pressure to the rails.
Thanks for correction, I was thinking of another pump design
Old Dec 23, 2016 | 10:13 AM
fordman67's Avatar
fordman67
Originally Posted by 1bigjoe
new -injector -orings----
new ipr
new cps
new ipc
new icm
new uvch
new pigtails
new glow ps
injectors buzzed
ipr orings look good
where did you get the IPR from?
Have you cranked engine with valve covers off to make sure no orings were cut?
What was the duty cycle doing while cranking at that 140 psi. It should have been from my experience 50% and rising or there about.
We had your same issue on my brothers truck a while back and at 300k a new IPR and t500 and it runs better than it had in 100k. More pep in its step for sure.
Old Dec 26, 2016 | 01:40 PM
1bigjoe's Avatar
1bigjoe
what do you mean when your talking about ( duty cycle )
Old Dec 26, 2016 | 03:20 PM
fordman67's Avatar
fordman67
IPR is measured in duty cycle% .on vs off . letting oil back to tank to control pressure vs flow rate.
ICP is pressure.
Pressure is regulated via IPR based on ICP feedback psi.
Old Dec 28, 2016 | 07:42 AM
1bigjoe's Avatar
1bigjoe
that's over my head
I saw on the XDP--site they sell hpop0005x bosh
is that the same as riffraff
xdp has a shop about 5 mi from here
Old Dec 28, 2016 | 08:01 AM
knottyrope's Avatar
knottyrope
that's over my head
You need a scanner and start to trouble shoot before tossing big coin at unknowns. Unless you are rich and don't care.
Old Dec 28, 2016 | 09:46 AM
duck fan's Avatar
duck fan
Because racetruck
that's over my head
I would check it before replacing but to answer your question, no they aren't the same. Riffraffs is a 17º and XDP is a 15º.
Tugly
57
Aug 6, 2020 12:35 PM
My Old Tools
Nov 10, 2018 09:47 AM
jkidd_39
Mar 3, 2012 11:13 PM
Ford_Six
Jan 18, 2012 08:33 PM
