what goes wrong with them----?
I got mine out yesterday--- wasn't building enough pressure
how does it build pressure???
can I rebuild mine?
when I take it apart ---and I will--- what should I be looking for??
every thread I read says buy the t500 from riffraff---ok I just might do that
but that a bosh pump--
-does riffraff do something to the bosh pump??
my little school bus just needs to make it to the grand canyon and back
I'm not looking for any thing more than that
in dirty jerzy
They usually don't just fail, they get weaker with time. I've heard they are next to impossible to take apart and if you do you might lose you core for a trade in. The T500 is a great hpop, I have the adrenaline which I think is just a tad better.
some nice young man on the fourm came over with his scanner--140 psi----- not enough
somebody takes them apart--to do there '' reman ''
has anyone on this site rebuilt one on there own
I looked through countless threads
just woundering--- not going to grand canyon in the winter
I have time on my side---- don't need the bus its a toy
don NOT even try it. Its not something possible for anybody but the professionals. I tore one downdown and without special tools you can't reassemble and tear down will likely ruin the valuable core.
You probably have a bad IPR or at last orings or a bad injector upper orioring. Those will cause low hpop pressure.
