Vent window seized shut
Old Dec 22, 2016 | 04:57 PM
ct50f1's Avatar
ct50f1
Originally Posted by JPMallory
I broke a pivot as well. They don't reproduce them for the 48-52, so as stated above, be careful.
Both of mine were seized up. I was able to get the unbroken one free with some penetrating oil, but only after I had removed it from the door.
I broke the one on the passenger side trying to free it. Ended up buying a junk frame with a decent pivot still attached. Rivited the pivot from the junk frame onto the one I had which was in good shape. Came out pretty good.
Ibuildmyown's Avatar
Ibuildmyown
Instead of all that expensive stuff , put you some transmission fluid in a pump oil can . For really rusted bolts and other things add a small amount of diesel to the trans fluid . Used trans fluid works as well as new. Try it before you knock it. It works for me every time. It won't hurt the rubber either.
Old Dec 23, 2016 | 03:24 AM
bokker's Avatar
bokker
Hi, just reread and didn't ever think about rust eater before using freeing oil. Cheers .
Old Dec 27, 2016 | 10:41 PM
dmack91's Avatar
dmack91
Mine wasn't seized at the upper pivot, but at the lower where the nut and spring are. One solid mass of rust.
I cleaned it up with a wire brush and heated the seized nut up red hot with an oxy/acetylene torch. Came right off and worked fine afterwards.
DougofMontana
Jun 22, 2015 10:30 PM
Bertha1
May 20, 2013 10:48 PM
nflfreak43
Jan 24, 2009 02:17 PM
burlii
Aug 26, 2002 07:36 AM
