Sport trac A/C problem...changes vents
Old Aug 26, 2003 | 02:17 AM
JohnChap's Avatar
JohnChap
Angry Sport trac A/C problem...changes vents
I have a 2001 Ford sport trac. My problem is that when I press the gas hard and I have it on the top vents It will swith by itself to half vents and half defrost. When I let off the gas a little it will switch back. Can someone please help!
Old Aug 26, 2003 | 05:58 PM
HomerWinzlow's Avatar
HomerWinzlow
Sounds like you have a vacuum leak. If its under warranty have the dealer fix her up. Otherwise you can look for vacuum lines loose on the actuators, broken vaccuum line, vacuum line off on the water control valve if it is equipped, or the vacuum cannister may be leaking or the vacuum check valve may be bad.
Old Aug 26, 2003 | 06:10 PM
JohnChap's Avatar
JohnChap
Thanks alot I will check all of that.
mark ryan
Apr 4, 2012 06:51 AM
Furyman
Dec 1, 2011 08:43 AM
FatDutchMn
Aug 12, 2006 03:19 PM
jmwhelchel
Dec 13, 2004 02:37 PM
