A/C Air Flow Problem
Old Aug 26, 2003 | 01:12 PM
bradleyj's Avatar
bradleyj
When I turn the selector **** in my 93 Bronco to MAX A/C, everything works fine as long as the engine is idling. However, when I begin to drive (engine RPM's increase), the cold air stops coming out from under the dashboard and starts coming out through the defrost vents on top of the dashboard. When I set the switch to NORMAL A/C, everything works fine. Anyone have a clue what's going on here?
Old Aug 26, 2003 | 02:23 PM
aerocolorado's Avatar
aerocolorado
Vacuum line problem - either loose at a fitting or a broken/cracked line. Air from the defrosters is the default setting for vacuum line problems.
Old Aug 26, 2003 | 06:51 PM
HomerWinzlow's Avatar
HomerWinzlow
Yes, vacuum leak. It could be that since it only happens in max ac, the line to the recirc door is the culprit, or the actuator itself. It could also be the vacuum switch itself.
dievert
1997 - 2003 F150
Nov 18, 2011 05:31 PM
pete315
Jun 8, 2010 07:42 AM
jbonbright
Feb 4, 2005 07:02 PM
Nevin
Aug 5, 2004 02:20 PM
AlexDeLarge
Dec 19, 2003 10:59 AM
