Huston Do We Have A Problem.
Old Dec 14, 2016 | 04:06 PM
bstarz40's Avatar
bstarz40
I need some help here. What do you guys think? A bad Gauge, bad probe or something worse? trying do put up video but it wont let me. but anyway my egt gage jumps all over the place on hard acceleration. If I accelerate smooth it works fine.
Old Dec 14, 2016 | 04:08 PM
HKusp's Avatar
HKusp
By the description, gauge, probe or the wiring itself. I doubt that the EGT's are jumping around too quickly. How does the truck feel?
Old Dec 14, 2016 | 04:12 PM
bstarz40's Avatar
bstarz40
Runs like it allways did. failed to mention that the gauges are glowshift max tow
Old Dec 14, 2016 | 04:15 PM
HKusp's Avatar
HKusp
Gauges can and do go bad. I have had trouble with SEVERAL transmission gauges and usually it was the wiring between the sender and the gauge. It would do as you are basically describing.
Old Dec 14, 2016 | 04:18 PM
bstarz40's Avatar
bstarz40
Ok thanks Will do some checking into wiring before I buy a new probe.
Old Dec 14, 2016 | 04:23 PM
RV_Tech's Avatar
RV_Tech
My money would be on a loose connection.
Old Dec 14, 2016 | 04:39 PM
Bill Kay's Avatar
Bill Kay
Mine was doing the same thing and it turned out to be the ground. I was sharing a ground wire for all three of my gauges. I ran a separate one just for the pyrometer and the bouncing stopped.
Good luck!!
Old Dec 14, 2016 | 05:30 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
I agree, sounds like a gauge issue. Check all connections first, because a bad ground can cause the issue you are having. The thermocouple/probe is sensitive too, so make sure it has no damage.
That being said, Glow Shift has a bad reputation for quality. You may not physically find any damage, but the gauge could be faulty.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
chuck7300
Jun 25, 2016 10:22 AM
yamaguy
Feb 23, 2008 07:59 AM
Oleblue74
Aug 13, 2005 11:54 PM
mrw1125
Jan 17, 2004 10:11 AM
