'76 F250 Bed
Old Dec 14, 2016 | 01:44 PM
CFarrell's Avatar
CFarrell
'76 F250 Bed
Hi, guys. I'm new here, but had a question for you. I recently got a 1976 F250 4x4 with a flatbed on it. I just picked up a bed from a 1976 F250 2x4. I know that the Highboy frame is 4 inches narrower and that I'm going to have to drill new holes to mount it to the frame. Are there any other special modifications I'm going to have to do do make it work? Also does the bed mount directly to the frame with carriage bolts or is there any bushings or rubber that I've got to put in there? Thanks
Old Dec 14, 2016 | 02:56 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If you do not want to drill holes in the new bed, weld some tabs on the outside or inside (which ever matches your new bed holes) of the frame to match the current bed holes and drill the tabs.
I believe shims of some sort of material are used. Plastic, metal washers..?
Old Dec 14, 2016 | 04:33 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Before you mount that baby, power wash the snot out of the underside and seal the seam at the wheel well.
All mine mount directly to the frame.
Old Dec 14, 2016 | 05:09 PM
CFarrell's Avatar
CFarrell
Awesome, thank you guys. A couple people have told me it mounts directly to the frame, just wanted to be sure. I appreciate the info. I'll post some photos when its done.
Old Dec 15, 2016 | 12:09 PM
CFarrell's Avatar
CFarrell
Heres a couple photos of the truck and bed. It's a 1976 F250 4x4 with a 390FE motor that I got from the original owner who used it as a ranch truck. Has pretty low miles and runs great. Bed is from a 1976 F250 2x4.
Old Dec 15, 2016 | 02:43 PM
hickory1991's Avatar
hickory1991
Nice bed. Where did you score that, it's in nice shape.
Old Dec 20, 2016 | 06:36 PM
four-sixty-power's Avatar
four-sixty-power
Sometimes metal washers are used under the box to lift the box a little to line up the bodylines from cab to bed, I've only had to do that when new cab poly mounts were used.
Tank77
Jun 20, 2015 11:09 AM
kc0stp
17
Nov 2, 2012 12:49 PM
650
Aug 7, 2010 12:25 AM
94F250XL
Dec 6, 2009 07:18 PM
BigJake34452
Jan 16, 2009 04:00 PM
