Scanner Parameter Questions
Old Dec 14, 2016 | 08:58 AM
WolfCreek540's Avatar
WolfCreek540
Question Scanner Parameter Questions
I have the iPhone app "DashBoss" and use it to monitor my 2006 F350 and really like having the ability to monitor so much data. I just don't know enough about the numbers from a few of the sensors to know if there is anything wrong. I get the basic temperature and electrical safe ranges, but what is the range for the following parameters that is considered healthy?
IPR%
ICP Psi
MAP inHg
Just looking for info about when to become concerned. So far the truck is running as good as it ever has at 160K miles. Hope to keep it for a long time.
Old Dec 14, 2016 | 09:09 AM
WatsonR's Avatar
WatsonR
idle numbers when at full temp of 188-190*
IPR 21-23%. KOEO 14.9%, max 84.9%, start-up could be 80%. 2500 rpm-40% in park
ICP minimum to start 500+, idle 580-650, max 4000 psi
MAP 14.7 at KOEO, 16-17 at idle, goes up with throttle, could be 44psi. Normally its BARO+Boost=MAP
Old Dec 14, 2016 | 04:49 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Here is a nice spreadsheet a member put together a while back.
https://www.ford-trucks.com/forums/a...4&d=1424302615
Old Dec 14, 2016 | 05:01 PM
87crewdually's Avatar
87crewdually
Here's readouts if you like pictures instead of a spreadsheet. This is @ hot idle on my 2005 using Forscan.
BARO will change depending on elevation, 14.7 being at sea level.
2005 F350 6.0l DRW @ hot idle
Old Dec 15, 2016 | 11:15 AM
WolfCreek540
Super! Just got in from plowing the interstate for 12 hours and found the replies. Thanks a lot!
Old Dec 17, 2016 | 06:12 PM
Burgess090906's Avatar
Burgess090906
Thanks for posting this.
jessev1978
Jul 20, 2019 10:09 PM
McBusiness11
Apr 8, 2017 12:49 PM
navistarnut
Dec 15, 2015 08:21 PM
907steveb
Oct 16, 2014 10:02 AM
KRDiesel
Apr 21, 2013 07:39 PM
