Need help
Old Dec 11, 2016 | 10:07 PM
Mike temes's Avatar
Mike temes
Need help
I have a 2000 f350, 7.3l, it will not run, my scanner says no communication, I have replaced the PCM, IDM, GEM, injectors and glow plugs, got power to the OBD II @ pin 16, I have power at the 71 pin on PCM I have ground at pin 77 on PCM and power at pin 55 on PCM, it will crank but no fire, no communication, any ideas will be greatly appreciated
Old Dec 11, 2016 | 11:09 PM
r2millers's Avatar
r2millers
You might have this moved to the 7.3 forum as the guys there are more specific to this issue.
Old Dec 12, 2016 | 04:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
Moved to 1999 - 2003 7.3L Power Stroke Diesel forum.
Good luck and welcome to FTE, Mike temes.
Old Dec 12, 2016 | 08:49 AM
tommyl's Avatar
tommyl
Have you checked your fuses? Fuel bowl heater shorted out!
Old Dec 12, 2016 | 08:58 AM
Rikster-7700's Avatar
Rikster-7700
What scanner are you using? Not all scanners play nice with our trucks as they are not truly OBD II compatible....
Old Dec 12, 2016 | 10:17 AM
blckjck's Avatar
blckjck
Are your batteries fully charged?
Key on, engine off.
Measure voltage between PCM Power Test Pins 55, 71 and 97 and PCM Ground Test Pins 25, 51, 76, 77 and 103. Note voltage.
Measure voltage across battery terminals. Note voltage.
Are both voltages greater than 10.5 volts, and are both voltages within 1.0 volt of each other?
EDIT: Some of these test ask for a breakout box (Ford Rotunda 014-00950). I don't know if you have access to one. One can be made, all be it a PINTA, from recycled connectors. Some of the tests may work without the box. You may be able to find a used one at a price acceptable to you.
Old Dec 12, 2016 | 10:29 AM
blckjck's Avatar
blckjck
Also, does the CEL come on during the bulb check? Meaning when you first turn the key, does the bulb light?
When you crank it, does it crank fast? Is the exhaust smokey?
Old Dec 12, 2016 | 05:58 PM
dn29626's Avatar
dn29626
Originally Posted by Mike temes
...2000 f350, 7.3l, it will not run, my scanner says no communication...
...I have replaced the PCM, IDM, GEM, injectors and glow plugs...
...it will crank but no fire...
The scanner may not be compatible.
At what part did it stop running?
Does the fuel pump have power? (the comment from tommyl, post #4)
Old Dec 14, 2016 | 08:36 AM
MoBill122's Avatar
MoBill122
Papa Smurf
Replaced the CPS....Crank Position Sensor ?
6.0techwannabe
23
Jan 2, 2020 04:06 PM
strokinaintez
Dec 30, 2015 10:30 PM
finallyo3gt
17
Nov 14, 2015 10:43 PM
frustrated mechanic
2004 - 2008 F150
Jun 5, 2015 09:45 PM
bluestang65
Aug 9, 2011 10:10 PM
