zf5 swap in 2wd extended cab from m5od driveshaft question
So I just had a driveshaft rebuilt(all new spicer parts...all three u joints and carrier bearing). That said I've been wanting a zf5 and I found one cheap. If I do the swap, does the slip joint swap out at the ujoint for the zf5 shaft or will I have to purchase a whole new driveshaft?
I sold a zf5 from a small block to a guy that was putting it in a older Bronco that had the same trans you have. He told me that everything would swap over, wasn't sure if he also meant the driveshaft or not.
Also I read a write up from a Bronco Forum that had the same write up and it said that everything would swap over. If I can find the article again i'll give it to you.
https://www.ford-trucks.com/forums/1...-progress.html I just found this on our Forum.
88gtblack
06-05-2013 06:18 PM
superbepro
10-08-2006 08:12 PM
jmalecek
01-12-2004 10:04 PM
