After some cleaning, I've been reassembling my truck, and right now I am stuck on the lower intake. I'm not sure which bolts go in which holes on the intake. If anyone knows please help me out. I included some pictures and labeled everything to try to make this simpler.
Any knowledge y'all have of this would be greatly appreciated,
Thanks - Doug
Studs B go in the rear holes 6 and 12 where wiring grounds are attached. Studs C go in holes 10 and 11 to hold the bracket for the coil.
Bolts A go everywhere else.
P.S. You may know this but the sensor you have inserted near bolt 8 is in the wrong place, that is the coolant temp sender for the dash gauge and it should be in the hole near bolt 7. The hole that sensor is currently in is for the IAT(intake air temp) sensor.
Thank you so much! I didn't realize that no. I had taken it out and just had it sitting in there so I wouldn't loose it, and chances are it would have given me some headaches later. Thanks for your quick help.
