Power Steering Conversion
Old Aug 25, 2003 | 08:00 PM
klatta's Avatar
klatta
I am converting my 69 F-250 to power steering.
I am having rpbolems getting the steering box to bolt into place. It seems to run into the engine mount and frame.
Any Ideas?
Old Aug 25, 2003 | 08:11 PM
willowbilly3's Avatar
willowbilly3
What did the steering box come off of and what engine do you have?
Old Aug 25, 2003 | 09:01 PM
klatta's Avatar
klatta
We purchased a rebuilt steering box FOMOCO style.
The engine is a 360
Old Aug 25, 2003 | 09:10 PM
moonley's Avatar
moonley
what application was the steering box for? If you don't know, what does it look like, or what are the casting numbers?
Old Aug 25, 2003 | 10:44 PM
klatta's Avatar
klatta
The casting numbers have been painted over a few times making them difficult to read.
I copied down "DITR-3550-8a"
Old Aug 25, 2003 | 11:27 PM
sparky's Avatar
sparky
You either have to change the drivers side engine perch to an FE perch from a power steering equipped truck, or do a little grinding. The drivers perch is shaped different on a PS truck versus a non-PS truck.
Old Aug 25, 2003 | 11:31 PM
klatta's Avatar
klatta
Thanks for the advice
Old Aug 26, 2003 | 01:58 AM
willowbilly3
Wow sparky, I never knew that. I have been around these trucks since 1977 and I still learn things. So when you put p/s on an FE truck you need the engine perch? I haven't even heard this mentioned before. I have done the conversion twice, but never to an FE. Thanks
Old Aug 26, 2003 | 12:04 PM
klatta's Avatar
klatta
Any ideas where I can get a perch, or where I can get a picture of one?
I called my local wrecking yard and they did not have any known inventory, or know specifically what I was talking about.
Thanks
Old Aug 26, 2003 | 02:58 PM
jas88's Avatar
jas88
I did this same conversion on my 1968 F-250 and you do need a different engine perch. The Ford box is much bigger than the Bendix box which was used on the 1968 and early 1969 trucks. The required perch slants forward a little (toward the radiator) to make room for the Ford box. If you look at your frame, you will see a hole just forward of the existing perch. This is one of the holes your new perch will bolt to. The other is covered by the existing perch but it is up under there.
I think the 1970-up trucks with FE all had the same perch but just see if it is bolted to the forward set of holes or not to tell if it is the one you want.
Old Aug 26, 2003 | 03:09 PM
zakt's Avatar
zakt
I will also be doing the PS conversion but have that 2wd crossmember...Im swapping a 460 in using the L&L motor mounts (towers) . does anybody know if I will have any problems there?
Todd
Old Aug 26, 2003 | 05:44 PM
sparky's Avatar
sparky
I have one on a truck I am presently piecing together.....I will try and borrow a camera and take a picture of it.
It is as jas88 says slanted forward and kind of flat on top...compared to the other.
How much of a hurry are you in?? It may be a day or two before I can get a picture of it.
Old Aug 26, 2003 | 05:51 PM
BB's Avatar
BB
Not sparky (or ever could be) but you don't have to change the perch, just grind out the notch but it won't be as purdy.
Barry
Old Aug 26, 2003 | 06:54 PM
sparky's Avatar
sparky
Right you are, Barry, grinders and torches are our friends
And a creative guy could grind it out, weld the hole up real nice, splash some paint on it and "Viola" custom engine perch
Old Aug 26, 2003 | 08:08 PM
willowbilly3
So only the bendix equiped years had the interfereing perch? If converting a 70 or newer there will not be an interference problem? I converted 2 72s, a 300-6 F-250 and a 302 F-100 and had no such problems.
