So I attempted to drain the HFCM today on my 2013 powerstroke and a blue/greenish liquid came out (which I assumed was diesel) so I did not drain much. I tighten the cap as much as I could and started driving and the check engine light came on. I ran the codes and it said something to the effect of reduction in power. I cleared the code, tightened the drain plug and the light came back on a few minutes later. Anyone have any thoughts or ideas on the issue here??
I just bought the truck so it is currently under warranty. At first, I though I just didnt tighten drain plug enough which was causing it to leak. Now I'm thinking I may have overtightened the drain plug which supposedly could have it leak along the frame rails. Not sure.
If it is somehow sucking air into the DFCM through the drain valve, or anywhere else, you will get low rail pressure and cause a reduction in power. You may have pinched or rolled the O-Ring in the valve and allowed it to suck air.
Turns out there was rear pinion seal that was loose. 80 dollar fix.
I'm scratchin' my head a little here. So, the blue-green liquid was gear oil? And soothing you loosened allowed some to escape? And a leaking pinion seal throws a code? Just to keep me from laying awake tonight trying to figure this out, can you fill in a few blanks for me?
