6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Drain yo vain
Old Mar 7, 2009 | 06:29 PM
deadbug's Avatar
deadbug
Drain yo vain
How many of you drain your seporator every month ?
I know not every one does but just curious
Old Mar 7, 2009 | 06:53 PM
senix's Avatar
senix
I think I have been getting it. But to tell you the truth I am not really tracking it.
Old Mar 7, 2009 | 08:00 PM
sawtooth's Avatar
sawtooth
Me. I do mine each month
Old Mar 7, 2009 | 08:13 PM
firemansdiesel's Avatar
firemansdiesel
I drain it once a month. Its been a habit since my last truck. I just drain it for a few seconds and shut it off.
Old Mar 7, 2009 | 10:11 PM
BENSFORD's Avatar
BENSFORD
every 6 months
Old Mar 8, 2009 | 10:15 AM
CampD's Avatar
CampD
usually every couple months, but I was bad this past one and the truck yelled at me to drain it!
Old Mar 9, 2009 | 07:44 AM
caprang's Avatar
caprang
Every 4-6 weeks. Im not religious about doing it the first day of every month but rest assured its not neglected. All it takes is one tank of fuel with water in it. Even if you pump from the same station every time you just never know. If I was 100% sure that the fuel I was buying was perfect then I might extend that interval but since I cant analyze the fuel before pumping it I am not taking the chance.
On the 6.0 you had to remove an allen head plug and it would drain all over the place. The 6.4 is soooooo easy with the lever and even has a nipple to attach a hose to. If it were any easier it would do it for you. Even if you havent had problems yet my advice is not to risk it. Takes 30 seconds and no mess at all.
Old Mar 9, 2009 | 08:02 AM
deadbug's Avatar
deadbug
Wow, Light just went off
Imagine installing a switch that would open the valve from inside the truck. ooouuuhhh
No more crawling under
Old Mar 9, 2009 | 08:14 AM
caprang's Avatar
caprang
Only 1 problem. What would you drain it in to?
Old Mar 9, 2009 | 08:20 AM
bricole1973's Avatar
bricole1973
Since we're on the topic of draining the separator, where does everyone dispose of the stuff?
Old Mar 9, 2009 | 09:24 AM
deadbug's Avatar
deadbug
I send mine to to Ford
Actually straight onto the ground which I know is bad
I'm sorry someone please help me better a better
visitor
Old Mar 9, 2009 | 09:26 AM
deadbug's Avatar
deadbug
I guess you would install a another tank which of coarse you'd have
to get under the truck to drain
Old Mar 9, 2009 | 10:10 AM
senix's Avatar
senix
I just drain it into a coffee can and since it is such a small amount I throw it in the lawn mower.
Old Mar 9, 2009 | 01:09 PM
firemansdiesel
I use an old pickle jar and dispose of the fuel at the fire station's maintenance shop (oil/fuel disposal containers) when it gets full.
Old Mar 9, 2009 | 01:47 PM
caprang's Avatar
caprang
I pour it in an old milk jug. When its full I run it down to a friends shop that uses old oil to heat his shop. He just pours it in the tank and its free heat to him.
I have a friend that pours his in to his kerosene heater.
