427 Interceptor value
Old Aug 25, 2003 | 05:36 PM
uniflitefixer's Avatar
uniflitefixer
I've got a boat with two top-oiler 427s in it. I'm considering selling the engines, but am curious about their value. One has been rebuilt, the other has not. They both run well. Any ideas out there?
Old Aug 25, 2003 | 07:39 PM
fordeverpower's Avatar
fordeverpower
No idea but I'd love to have them
Old Aug 25, 2003 | 09:19 PM
hotrodfeguy's Avatar
hotrodfeguy
Depends on where you live
Seriously They should be worth around 750-1500 depending on condition and rotation of crank.Some had reverse rotation,not a good thing in a Hot Rod
Also to note would be if they had the CJ style, low riser heads or std heads they came both ways.
Old Aug 26, 2003 | 02:30 PM
pward76's Avatar
pward76
There's a pair of them on ebay right now for around $4000 - though one is a top oiler and one is a side oiler. I was wondering if one of them was reverse rotation....
Stupid question...If it was a reverse rotation, couldn't it be stripped down to the block and rebuilt as a correct rotation engine?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2428491970
Old Aug 26, 2003 | 02:35 PM
gtex's Avatar
gtex
I believe you only have to change the cam and starter arrangment.
Old Aug 26, 2003 | 02:44 PM
BB's Avatar
BB
The dizzy needs to be changed too. Only problem is the reverse crank has the oil slots on the rear main cut to sling the oil back inside the engine. Spin the crank the other way around and the slots sling the oil out through the seal and onto the ground. Can't grind out the slots 'cause then the od becomes too small for the seal to work right. Someone else here had that problem.
Barry
Old Aug 26, 2003 | 02:51 PM
pward76's Avatar
pward76
Thanks gtex and Barry
So would a "correct" crank work? I guess my question should have read : Can you use a "reverse rotation" block to build a correct rotation engine, using correct rotation parts.
Old Aug 26, 2003 | 03:15 PM
BB's Avatar
BB
Sure, the block doesn't know which way things are turning.
Barry
Old Aug 26, 2003 | 03:40 PM
pward76's Avatar
pward76
Well, that was my thinking - but I've been wrong before...
no, no it's true... I thought I had made a mistake once, but I hadn't.
Old Aug 26, 2003 | 10:25 PM
gtex's Avatar
gtex
You can't just change the wiring order instead of changing the dizzy?
Forgive me if sounding stupid...On beer 3 and looking at a 4 day weekend.
Old Aug 27, 2003 | 12:11 AM
BB's Avatar
BB
Well, I guess you could change the distributor drive gear, it's backwards too. The marine engines I've seen used a Mallory single or dual point unit with the flat 'crab' cap.
Got that case down yet?
Barry
Vincent Cimino
Engine Swaps
Jul 18, 2020 10:01 AM
scottzilla
79
Mar 13, 2017 12:13 PM
wld427
28
Sep 21, 2012 06:49 AM
Power_age
Dec 14, 2004 02:31 PM
mastermecanic302
Jul 22, 2004 05:20 PM
