Starter not working.
Old Dec 4, 2016 | 09:30 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Drove the truck around a little today. Brought it home changed the oil and fuel filters. Buttoned it up and went to start the truck. Starter engauged and worked for about a second then stopped. When you turn the key everything happens as it should except the starter. Put the truck in neutral (6spd) and disconnected the push fitting under the hood. Put it to the positive post on the battery and got nothing. Im guessing i need a new starter. Is there any breaks in power past the push fitting under the hood to the starter?
Old Dec 4, 2016 | 09:43 PM
WatsonR's Avatar
WatsonR
Nope. You need a starter... as long as the batteries are good. Check for 12v at the starter solenoid.
Old Dec 4, 2016 | 09:53 PM
87crewdually's Avatar
87crewdually
I agree. You can check the connections on the starter and battery voltage. If they look good and still nothing, time for a new starter.
Old Dec 4, 2016 | 10:25 PM
Lubbockguy1979
Kinda what i was thinking. Its cold and had stuff to do so i didnt do the due dilligence of checking voltage. The edge evo shows 11.8v and the headlights are fairly strong. Thinking of hunting a 6.4 or 6.7 starter as that seems to work and help start the truck faster
Old Dec 5, 2016 | 08:19 AM
TooManyToys.'s Avatar
TooManyToys.
If the brushes are stuck a moderate rap on the starter with a hammer can get you going again for a short time.
Old Dec 5, 2016 | 01:14 PM
Lubbockguy1979
That was my thoughts. Last night i had my bro inlaw there and his mechanical aplitude not what id expect from my 4yr old. We just pushed it out of the drive way to make the wife happy. Ill probably go bang on it tonight and see if i can actually park it in a better place to work on it. Looked at starters last night and im thinking bout sitting on santas lap this year
Old Dec 5, 2016 | 07:10 PM
Lubbockguy1979
Stupid truck started right up tonight. Didnt do anything other than turn the key. Damn tempermental 6.0
Old Dec 5, 2016 | 07:28 PM
WatsonR's Avatar
WatsonR
Solenoid is going.... get yourself a used 6.7 starter.
Old Dec 5, 2016 | 08:26 PM
Lubbockguy1979
Yeah its now the when will i be stranded game.... good thing i dont depend on that truck... keep finding more reasons to drive the 2016 and it dosent take alot
Old Dec 5, 2016 | 08:43 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I carried an engineer's hammer in my Ranger. It wasn't every start, but one a day or two. Strung that sucker along for a couple months. Changed it in the parking lot of Autozone at 50th and Indiana actually, I had to get push started out of the Sonic by Monterey.
Old Dec 5, 2016 | 08:49 PM
Lubbockguy1979
Spent alot of my youth in that specific autozone.
Old Dec 6, 2016 | 10:57 AM
Copper.Farm's Avatar
Copper.Farm
As long as your batteries are good, if you choose to not upgrade to a 6.4 starter at the moment you could disassemble the starter solenoid - The solenoid has two poles shaped like the head of a mushroom, the poles can usually be removed and rotated by 180 degrees to provide a solid electrical connection between Battery+ and the actual starter motor.
Old Dec 6, 2016 | 11:00 AM
TooManyToys.
And with some you can do a little work to flip the contact disc over depending on the design. I had to do that this summer with the Perkins diesel in my Vermeer chipper.
bigdogchris
1978 - 1996 Big Bronco
Apr 28, 2012 07:21 PM
mac01
24
Nov 27, 2009 03:01 AM
guitarnik
Sep 2, 2008 08:04 AM
StrongRepublican
22
Feb 19, 2007 02:20 PM
ford390gashog
Feb 14, 2004 11:54 PM
