Why?
Old Dec 4, 2016 | 08:19 PM
Clifford Petersen's Avatar
Clifford Petersen
Question Why?
Why would my 05 f350 6.0L have coolant coming out of the exhaust?
Old Dec 4, 2016 | 08:44 PM
r2millers's Avatar
r2millers
Unless it's condensation at start up, the only way it could get there and still run relatively good would be thru the egr cooler. If your oil cooler is plugged, the coolant flow to reduce the egr temps can't work properly.
As a result, your egr will super heat, then crack, and allow the limited amount of coolant running thru it, to go back into the intake as the exhaust gases would normally go.
Not a good thing as you can hydrolock your engine before long, once that crack opens further.
I would be very careful about running the engine until you have it checked out. If you monitor eot and ect, you would probably see a 20 plus degree difference when driving.
The only other way would be to have a warped head or blown head gasket. If Either of those were the case, your engine would really run rough.
Old Dec 4, 2016 | 08:51 PM
BLADE35's Avatar
BLADE35
welcome to FTE
r2Millers has you covered
good luck
Old Dec 5, 2016 | 06:23 PM
2006powerstroke90's Avatar
2006powerstroke90
If you have stock EGR system pull EGR valve and see if its wet.......Thatll tell you on a blown EGR cooler
Old Dec 5, 2016 | 06:50 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Epa is why
Old Dec 5, 2016 | 06:58 PM
69cj's Avatar
69cj
If it's coolant, OP's words, it's not condensation.
Old Dec 6, 2016 | 12:09 PM
r2millers's Avatar
r2millers
Wouldn't be the first time someone didn't know the difference.
Yahiko
Nov 28, 2013 08:07 PM
RKCORPS25
Oct 13, 2013 07:32 PM
2004SD
Nov 5, 2009 03:35 PM
Headviking
Jun 6, 2009 09:38 PM
jmaskew
Jul 9, 2008 06:34 PM
