starter prohlems
Old Sep 2, 2009 | 07:37 PM
mac01's Avatar
mac01
starter prohlems
ok heres my deal... i went out the other morning to start my truck and it turned over about 5 times and it quit. so i made sure my cables are tight and i tryed it again...same thing again. but since then it won't do anything. i'm pretty sure its the starter cuz its been draggin for a while but i just wanted to get some other opinions. thanks
Old Sep 2, 2009 | 08:20 PM
joe f350's Avatar
joe f350
take ot get tested
Old Sep 2, 2009 | 08:46 PM
dyoungen's Avatar
dyoungen
If all the connections are good and the starter has been getting slower, I second the starter.
Old Sep 2, 2009 | 09:03 PM
joe f350's Avatar
joe f350
whell its probley the one form 83
Old Sep 2, 2009 | 11:57 PM
ford trans tech's Avatar
ford trans tech
Thumbs up
go to ebay search for 6.9l starter find a seller named 14rebuilders
they have a new aftermarket gear reduction starter that replaces the original starter
i replaced mine a few weeks ago and this starter spins the engine about three times as fast as the original and really helps eliminate hard starting
it was only about $125.00 including shipping
Old Sep 3, 2009 | 03:55 PM
84 f250 6.9's Avatar
84 f250 6.9
you wont regret spending the $ on a new starter I replaced everything except thr starter and until i got a new one I had the same results
Old Sep 3, 2009 | 05:25 PM
dyoungen's Avatar
dyoungen
If the starter is turning slow enough to be able to count the number of revolutions, that is not good.
Old Sep 3, 2009 | 05:42 PM
dyoung14's Avatar
dyoung14
i say you should buy the aftermarket high torque starter for the idi it cost about the same as the factory but it cranks a hole lot faster, mine died not to long ago but i didnt have the money to buy a starter and alternator so i bought a re man alternator and i took 2 junk starters and i built one and its working fine so far
Old Sep 3, 2009 | 08:03 PM
mac01's Avatar
mac01
thanks guys.. i thought it was the starter but i just wanted to know what everyone else thought.. i'll be gettin one tomorrow..
Old Nov 21, 2009 | 03:29 PM
Jon250's Avatar
Jon250
Ok, does anyone know a good way to get the top bolt in on a starter for the 84 F-250 6.9L?
Jon250
1984 F-250XLT 6.9L I.D.I. V-8 Diesel, C6 Trans, 2wd
Old Nov 21, 2009 | 05:37 PM
branden.w's Avatar
branden.w
i have an 87' and the top one is hard, just an extension on your ratchet will do.
Old Nov 21, 2009 | 06:36 PM
Happyreefer's Avatar
Happyreefer
I bought one from DB electric.. the first one was no good, they sent me out another quickly and that one worked great.. paid about 115.00 with shipping
Old Nov 21, 2009 | 07:27 PM
rupejosh's Avatar
rupejosh
i thought i was gonna be buying another starter then i checked the two scews on the starter solenoid and they were loose.so i tightened them up and problem solved and mine was doing the same thing your describing
Old Nov 21, 2009 | 09:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The older Nippondenso starters were a real pain to get the top bolt in and out.
This is a newer one, the motor has been reclocked and it does look like you can get a socket on the bolt.
The old ones, wrench only.
Old Nov 22, 2009 | 12:37 AM
ford trans tech
that is the starter i was talkng about
the top bolt requires a chrome flex socket to get to it
