Decided to try and swap in LED bulbs into the sub par factory headlights and since some engineer somewhere decided it would be easier for me to have to remove the grill and headlights just to change a bulb, I noticed that the dual horn set up had the horns pointing back to the truck. Even worse, right in front of all the fins on the CAC, Raidator, etc. to help muffle the sound.
Now I don't know how things are where you live, but generally when I honk at someone, I'm not doing it so I can hear my own horn. The general idea I thought was so that others could hear my horn.
Of course the same engineers in charge of headlight bulb swaps also figured out the wiring for the horns so you can't just loosen the nuts (10 mm) and rotate said horns 180 degrees. You can rotate the driver side horn 180 degrees and call it good, but the factory wiring won't reach the passenger side horn if you rotate it.
You can however remove both horns and use a small screwdriver to unplug the harness that joins the two horns. If you swap the horns right to left and left to right, then you can put the factory wiring back together in a manner that leaves the horn outlets pointing forward towards others.
Sorry I can't insert pics into the thread as I describe things. I used to do that but FTE seems to have gotten rid of my gallery so I can't upload to there anymore and then post photos in the thread that way. So now you get them uploaded as attachments at the end of my rambling.
I did the same thing on my 2013. Then I got caught in a heavy snow storm in Colorado. The horns got filled with road grime and ruined them. I decided to leave them alone on my 2016.
