Coolant
Old Dec 4, 2016 | 01:03 AM
bigreentruck's Avatar
bigreentruck
Coolant
OK, read some of the banter. I have a 2000 F350 7.3.
Should I be using the Red coolant or good to go on the regular green 50 50 pre diluted?
Old Dec 4, 2016 | 01:15 AM
IDI-Charlie's Avatar
IDI-Charlie
If you run green be sure to keep SCA levels up and check semi-regularly. While the ELC is more expensive, you don't have to worry about the levels near as much as they come pre-charged (I believe Rosella ELC is rated for 750k).
I switched over to red when I did my thermostat/water pump. I'd say run the green until you need to service the coolant system, then flush it out and replace with the ELC.
Old Dec 4, 2016 | 11:55 AM
SGnAZ's Avatar
SGnAZ
I use prestone HD elc and all is good
Old Dec 4, 2016 | 12:42 PM
Arizona97's Avatar
Arizona97
Bigreentruck, I have been using Chevron Delo ELC in both my 7.3 & 6.0 and plan on keeping it that way, Delo is good for 750,000 miles before change, I think it is worth a few extra bucks up front. Just my 2 cents.
Ed
Old Dec 4, 2016 | 05:26 PM
bigreentruck
Pardon my lack of jargon. What is SCA levels?
Old Dec 4, 2016 | 05:30 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
A quick Google search for what SCA levels are returns a ton of info, but here is a video that is a decent summary.
Old Dec 4, 2016 | 08:16 PM
pirschwagon's Avatar
pirschwagon
Anything meeting FoMoCo/Navistar Standards where your Truck was assembled and Build Date.
Reference:
GJenkins
Jan 14, 2010 09:34 PM
gtnwood
Apr 1, 2009 03:51 AM
makohon
31
Nov 9, 2008 09:57 AM
Firefighter 1406
13
Oct 1, 2007 01:08 PM
lowcan
13
Aug 7, 2007 10:57 PM
