Everything is fine going forward, but when i back up, both front tires lean in. My truck has a 4" lift. like i said everything is fine going forward, no shakes, rattles or anything. any thoughts?
If your susp. lift is like mine, check where the bracket for your axle bolts to the crossmember. Over time, the hole that the bolt (that stabilizes the bracket) goes through can wallow into a slot.
