1992 f150 e4od
Old Oct 5, 2007 | 09:16 AM
larry1211's Avatar
larry1211
Cool 1992 f150 e4od
I have a problem with this tranny....it started to not shift unless I unplugged the sensor on the differential then it would not shift unless I unplugged the map sensor,,,,now it wont shift at all ...changed the map,evr tps and nothing,,,It will go into reverse fine but nothing forward some please help
Old Oct 5, 2007 | 09:30 AM
Skandocious's Avatar
Skandocious
Welcome to FTE. Have you tried pulling the codes? I would start there:
http://www.fordfuelinjection.com/?p=13
Is the VSS in the rear diff still original? If this was affecting the problem before then it could be what is wrong...
Old Oct 5, 2007 | 09:43 AM
amcv8jeep's Avatar
amcv8jeep
mlps on the side of the case. around the shift lever rod.
Old Oct 5, 2007 | 11:04 AM
larry1211's Avatar
larry1211
changed the mlp no change I have a ford code reader and the only codes I get is 311 (thermactor right side )none on the tranny.....changed the vss on the differential about 4 month ago...can it possibly be the computer?? what is the sensor on the transfer case shaft for anybody know??
Old Oct 5, 2007 | 11:55 AM
larry1211's Avatar
larry1211
1992 f150
Old Oct 5, 2007 | 11:56 AM
larry1211's Avatar
larry1211
Tractorman1215
Dec 1, 2013 07:16 PM
hedhntr
Aug 16, 2012 12:55 PM
metriccar
Apr 23, 2012 08:45 AM
mohare7
20
Mar 28, 2008 08:20 PM
larry1211
Oct 6, 2007 09:41 AM
