90 f150 4x4 camber problem when backing
Old 08-25-2003, 04:03 PM
ltbeach's Avatar
ltbeach
ltbeach is offline
Everything is fine going forward, but when i back up, both front tires lean in. My truck has a 4" lift. like i said everything is fine going forward, no shakes, rattles or anything. any thoughts?
Larry
Old 08-27-2003, 03:06 PM
mstaser's Avatar
mstaser
mstaser is offline
It happens on every F-series 4X4 that I have owned
Old 08-27-2003, 04:11 PM
balingwire's Avatar
balingwire
balingwire is offline
If your susp. lift is like mine, check where the bracket for your axle bolts to the crossmember. Over time, the hole that the bolt (that stabilizes the bracket) goes through can wallow into a slot.
larkimg
1999 to 2016 Super Duty
05-02-2011 04:49 PM
HappyJack
Kansas Chapter
20
11-28-2007 08:06 PM
larry1211
10-05-2007 11:56 AM
LarryB_ca
Aerostar
01-01-2006 07:41 PM
Quick Reply: 90 f150 4x4 camber problem when backing
