Sponsored by: Real Truck
Tap throttle on shut down
Old Nov 29, 2016 | 09:08 PM
flysniper's Avatar
flysniper
Just curious here. Do any of you tap the throttle just before you shut down?
Hurt? Harm? No impact? Does it have any impact on the following start up?
Old Nov 29, 2016 | 09:16 PM
85e150's Avatar
85e150
Probably harmful. No proof. Think about though, you speed it up, feed it more fuel then cut the power, leaving a richer mixture in the cylinder as it comes to a stop.
No need to do it, no benefit, as habits go, probably in top 10 easiest to quit.
Old Nov 30, 2016 | 01:50 AM
Mike189677's Avatar
Mike189677
Why would you do that? Not sure what engine if anyone any in particular your asking about but You will find the diesel guys after working the truck hard will actually let it idle for a few min to cool the turbo before shutting it down.
Old Nov 30, 2016 | 06:36 AM
SHAWZER's Avatar
SHAWZER
A friend of mine had this stupid , annoying habit . Took years to get him to stop .
Old Nov 30, 2016 | 08:23 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Why, to accomplish what? and how/why did you start doing this.
carburetor type engines . it washes oil away from pistons..
fuel injection .. less harmful.. but NOT GOOD, same reason.
Old Dec 1, 2016 | 10:28 AM
Jeff in Ferndale Wa's Avatar
Jeff in Ferndale Wa
Maybe old school,but I've always believed that if you rev a little just before shutting off,it will dilute any oil film left on the cylinder walls,causing even less lubrication the next time you start up,causing undue wear over time.
Same people that rev on shutdown,probably rev on startup,compounding the problem.
dropitlow88
Aug 28, 2015 10:54 PM
Matt4467
May 14, 2015 12:08 PM
BillyBob69
Mar 2, 2011 08:02 PM
cummins cowboy
6.7L Power Stroke Diesel
15
Feb 18, 2011 05:38 PM
boulderbronco
6.4L Power Stroke Diesel
Jan 4, 2008 12:40 AM
