Question to those who have built a roof rack
Old 11-23-2016, 10:14 AM
tkmitchell's Avatar
tkmitchell
tkmitchell is offline
Did you make the standoffs all the same height, or did you make them different to follow rake of truck or get the rack level with ground?
Also, what clearance did you end up with between rack and roof?
Getting material and just starting mine.
I plan on using 1" sq tubing for base. 1" round for the upper rail and connect them with flat plate that has been drilled and use a dimple die for strength and weight savings.
Old 11-23-2016, 12:13 PM
gorkah's Avatar
gorkah
gorkah is offline
Hey there tkmitchell. I custom build my roof rack a few years ago and posted a write up on it before also, here is the link: https://www.ford-trucks.com/forums/1...l#post15600692
but to answer your question directly, I did NOT follow the roof line, I did NOT make the standoffs the same height, it looks silly because the excursion roof line starts high and slopes downward pretty severely.
I used aluminum bars, and cut standoff squares, and then drilled holes. I used one square in the front, 2 in the middle and 4 in the rear. The article I posted last year shows 2 in the rear, but I have since changed that design and run 4 in the rear.
The total lift in the back is exactly 1.5" standoff, while the front and mid standoffs are 0.35" 0.70" respectively.
That gave it a nice clean line, while not being exactly level, it gave the ex the best overall "level" look.
Old 11-23-2016, 12:28 PM
gorkah's Avatar
gorkah
gorkah is offline
Here is a more recent picture with some extra side plating that shows the horizontal slope better with the 4 spacers in the rear.
Just let me know if you want more pics, you know how we X owners are, we're pretty crazy with admiring our beasts
Old 11-23-2016, 05:20 PM
tkmitchell's Avatar
tkmitchell
Using little squares as the spaces is a great idea. That gives a lot of flexibility. I was going to weld little legs on mine, but I think I am going with your idea now. Just weld little tabs on the crossbars like you did for attaching it down.
Old 11-24-2016, 09:25 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
I built a stainless yak rack for mine. It was a quicky and I just went along winging it as I went. I used two round bars, one slid inside the other for easy width adjustment (and storing of the bars when not in use).
Attachment 288446
Attachment 288447
Attachment 288448
Attachment 288449
Attachment 288450
Old 11-24-2016, 09:30 AM
Snowseeker's Avatar
Snowseeker
Just little threaded plates slid into the roof tracks.
upper plate with bolts threw to sandwich the roof rail.
Attachment 288445
All stainless materials because I don't like rust.
Old 11-24-2016, 03:24 PM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Twitchyleprechaun is offline
Old 11-24-2016, 10:28 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Gorkah, do you have any photos of the bumper setup without the tire on there? Would like to see how the latching mechanism is set up on the bumper when it is closed/secured if you can pull that off. Very nice bumper and rack you have there.
Old 11-24-2016, 10:54 PM
gorkah's Avatar
gorkah
gorkah is offline
Thanks Mike! I'll see if I can get some time tomorrow to get some better pics and measurements.
Old 11-25-2016, 02:23 AM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
MORE PICS GORKAH!!!!!
Old 12-14-2016, 06:37 PM
Logan Sean Brewer's Avatar
Logan Sean Brewer
Logan Sean Brewer is offline
Gorkah
I need some help!!! I need to find some one to build me a roof rack kinda like yours. Any Ideas?
2manyrides
2017+ Super Duty
22
02-25-2018 01:16 PM
gorkah
09-01-2015 08:08 PM
unibodyslick
1961 - 1963 F100 Unibody
11-24-2010 10:11 PM
fsbronco1989
1999 to 2016 Super Duty
16
07-02-2009 10:39 AM
bad booger
03-22-2009 09:40 AM
Quick Reply: Question to those who have built a roof rack
