Pics of ladder/headache rack setups?
Title says it all. Looking for what others are using out their. I NEED a ladder rack, I Want a headache rack. The rear of the rack must be easily removable fo when I put the salt spreader in and out during the winter. This happens very often because we are primarily a roofing company. This will be for a 2018 ccsb f350. My currant spreader is a 1.5cubic yard western tornado. I'm thinking this will come very close to the back of the truck and I really would like the extra protection for that fancy power sliding rear glass! I also need somewhere to mount a beacon and the magnetic ones on top of the truck will no longer work. I know about the Trac Rac, we use those on our other trucks, but they no longer sell the headache rack attachment. Really like the magnum setup, but would love to see/hear from someone with there headache rack, rails, and rear rack
I just ordered a Magnum headache rack. Haven’t seen one first hand but there are a couple of members that have them and are happy with them. May add the rear rack at some point for canoe hauling but that’s down the road a ways. Check out this thread if you haven’t seen it already.
https://www.ford-trucks.com/forums/1...th-lights.html
Works But Pricey
A Magnum rack system will definitely accomplish what you want, but would get pricey by the time you buy all the pieces you need to actually use it as a ladder rack. A lot of full racks have a removable rear cross bar. Perhaps one that is vertical vs. following the contour of the truck would allow the spreader to be installed/removed....
https://www.magnummfginc.com/
+1 for the Magnum. The base rack includes a groove "rail" where the attachments they sell mount, including the ladder rack hardware.
Magnum lets you choose Hi-Pro (above the roof line but allows the 3rd brake light to be seen); Lo-Pro (level with roof line but obscures the 3rd brake light) and you can have powder-coat black or mill-finish bare aluminum. You can get with the sliding window cut-out or without. Here's my low-pro black rack, which is adding protection for the transfer tank and pump I'm installing plus gives me a place to mount some discreet strobes for plowing.
Thanks for the replies. Rob, does magnum make a rear rack that's actually as tall as the front? I might just go with the front rack and make my own rear rack using similar hardware as the magnum rear rack. I'm a pretty good home fabricator. I'd have to do it in steel and not alluminum, but I have a friend that has a Hydrodiping business with a full automotive waterborne paint set up, our there's also a local industrial powdercoater in town. I just Clint see swinging the $17-1800 dollar price tag on the rack, rails,rear rack setup. That's a big pill to swallow after buying a 50k truck plus tax and license
I really like system one ladder racks. I’ve had headache racks and Trac racks. 4 bolts and 5 minutes they are off. This kit was about $500 minus the ratchets strap, they are about $200. The stuff is engineered great. And rated for 600 lb like this, but adding rails that attach the 2 ups it to 1200lb. They also make angled top side tool boxes that are pretty slick but expensive.
Perhaps something like this would suffice for your rear rack. Cheap enough even you have to buy both pieces...800 pound capacity....
http://www.amazon.com/AA-Racks-Capac...1KTAZJY0AEX0CV
I do have have a nice machine, I also have a plasma cutter. I do not however have a spool gun to weld with alluminum. I know I can build the front rack, and this thread is to see what others might have come up with. I really like the sliding attachment groves on the Magnum, but that would be a whole lot of welding to Fab up something similar. Still looking at ideas!
