Injector out? help
Old Nov 24, 2016 | 12:28 PM
fordpride's Avatar
fordpride
Do you have a chip?
Old Nov 24, 2016 | 12:33 PM
fordguy390's Avatar
fordguy390
TS 6 pos. Im sending the chip in for swamp tunes when I send the cores in.
Old Nov 25, 2016 | 01:57 AM
BBslider001's Avatar
BBslider001
Originally Posted by knottyrope
Stage one with stock should be fine
https://www.ford-trucks.com/forums/1...l#post16688713
Yeah if you don't push it at all, tow anything, and basically drive it like a Toyota Tercel. Stage 1s will definitely get you running hot with no Intercooler. They push hot even with an IC. You need gauges, EGT minimum, and definitely know what you are doing when driving it.
This is pretty bad advice knotty. Someone could easily burn an engine up. I know how hot they run on an Intercooled truck. EGTs get up there pretty quick.
Old Nov 27, 2016 | 09:19 PM
fordguy390's Avatar
fordguy390
The problem was the little armature bolt broke if anyone ever has simular problem with the armature being loose.
Old Nov 27, 2016 | 09:24 PM
LeoJr's Avatar
LeoJr
Originally Posted by fordguy390
Any ideas on how to get it going cheaply for now? thanks for the help
Adding your location to your profile would help people close by chime in that they have a spare or used one to share.
Eric3131
Dec 3, 2017 10:04 AM
Maleficent
Oct 19, 2017 08:45 AM
factionos
Crossovers
May 19, 2015 09:16 PM
pick1967
May 29, 2014 10:49 PM
wulfman
Dec 22, 2013 04:54 AM
