Injector out? help
Old Nov 22, 2016 | 06:54 PM
fordguy390's Avatar
fordguy390
Injector out? help
My 1995 f250 7.3 was running rough and lope idle sounded like dead hole. After looking back injector on pass side want firing. I ohmed (all ~3.4) like others and checked voltage and was getting voltage to injector. i ohmed on harness to check good connection. no oil drains out from injector drain no engine speed differance when unplugged that injector. Any help or input is welcome!
Old Nov 22, 2016 | 07:32 PM
fordman67's Avatar
fordman67
Remove the coil and swap with another cylinder and see if the issue moves. Also check armature clearance while the coil is off. Less than .002 is a worn injector.
Old Nov 22, 2016 | 07:54 PM
fordguy390's Avatar
fordguy390
just upluged batteries to reset pcm and what not and not the whole bay shut down.
Old Nov 22, 2016 | 08:23 PM
fordguy390's Avatar
fordguy390
I put valve cover on and started and the whole bay shut down. didn't touch coil yet.
Old Nov 22, 2016 | 09:59 PM
fordpride's Avatar
fordpride
Sounds like bad uvch. The IDM will shut itself down to protect itself
Old Nov 22, 2016 | 10:05 PM
fordman67's Avatar
fordman67
What mike said^
Old Nov 22, 2016 | 10:53 PM
fordguy390's Avatar
fordguy390
just replaced uvch 5k ago changed pigtails. checked wiring back all checked. getting voltage to injector clip and moved coil to another injector and problem didnt move. Im thinking injector but what gets me is no oil at all is coming out of drain spout. could the dead heads play a role in this
Old Nov 23, 2016 | 08:15 AM
knottyrope's Avatar
knottyrope
what is armature clearance?
directions
http://dieselpro.ca/Poppet%20Valve.pdf
Old Nov 23, 2016 | 10:42 AM
fordguy390's Avatar
fordguy390
Its bad it just wiggles freely. im asking around rn for 1 to get me by untill i buy a set. Any ideas on how to get it going cheaply for now? thanks for the help
Old Nov 23, 2016 | 10:45 AM
knottyrope's Avatar
knottyrope
there is a parts wanted thread, craigs list or you can check ebay for one
Old Nov 23, 2016 | 10:52 AM
fordguy390's Avatar
fordguy390
sounds good! thanks for the help. Im not looking for race truck but would stage 1 and or stage 2 work with stock turbo or will it get too hot.
Old Nov 23, 2016 | 11:15 AM
knottyrope's Avatar
knottyrope
Stage one with stock should be fine
https://www.ford-trucks.com/forums/1...l#post16688713
Old Nov 24, 2016 | 10:16 AM
quesey's Avatar
quesey
What part do you need
I have a few extra parts for injectors
Old Nov 24, 2016 | 10:51 AM
fordpride's Avatar
fordpride
Stock turbo won't last to long towing with stageII's
Old Nov 24, 2016 | 11:04 AM
fordguy390's Avatar
fordguy390
Sounds good I just went with swamp (baby swamp) stage 1. Just waiting for them to ship. I heard they wake obs up pretty good.
