Starting problems when engine is hot
Old Nov 22, 2016 | 11:19 AM
Marco Venegas's Avatar
Marco Venegas
I have a 6.9 diesel F-250. It does start ok when the engine is cold. Starter is working well, very fast !! But when the engine arrives normal temperature and you stop the truck it is practically impossible to start the engine again. Any comments on this issue will be very welcome.
Old Nov 22, 2016 | 02:07 PM
Chevy_Eater's Avatar
Chevy_Eater
Tired/dying injection pump.
Old Nov 22, 2016 | 03:24 PM
Marco Venegas
Well, I did change the injection pump and put a rebuild one from Pensacola Diesel injection and the problem continue.
Old Nov 22, 2016 | 07:31 PM
Chevy_Eater
They sold you a bad one, it happens.
Only thing these engines need to run is fuel and compression. You have compression; you're not getting fuel.
To confirm do the cool water over the pump thing next time it does it. If it starts right up then it's a bad IP.
Old Nov 23, 2016 | 05:51 AM
Marco Venegas
Sorry but I am not an expert ! What is the cold water over the pump ? Thanks !!
Old Nov 23, 2016 | 06:03 AM
Dieselamour's Avatar
Dieselamour
The cold water over the pump thing is the process of pouring cold water over the pump body. Supposedly thiscauses all the tolerances to shrink and the pump resumes operation and causes the engine to start thing.
Old Nov 23, 2016 | 07:19 AM
tjc transport's Avatar
tjc transport
i ain't rite
pensacola diesel has a reputation of selling "rebuilt" injector pumps that are worse than the bad one you took out of the truck.
they repair pumps by replacing what looks bad. not rebuilding them.
Old Nov 23, 2016 | 08:57 AM
Marco Venegas
Ok I got it!! My mechanic is going to test it ! Do you know a good place to buy an IP ??
Old Nov 23, 2016 | 10:22 AM
Macrobb's Avatar
Macrobb
We trust R&D IDI Performance - Home
The prices may be a bit higher than others, but you are paying for quality and he stands behind his work.
You aren't in the performance market(I think), so you just need a standard NA calibrated pump ($690)
As far as testing your pump, the problem is that when you are trying to start the engine, it is moving too slowly to build up enough pressure to actually inject fuel into the engine.
This happens because the minute space between the rotor in the center of the IP, and the "head" which is where your injector lines attach, becomes large enough that all of your fuel pressure simply leaks out and returns to the fuel tank.
It's something that is hard for a cheap rebuild shop to test, because it only happens:
A. at cranking speed
B. with the IP head hot.
This happens due to "heat soak" from the engine, after shutting the engine off hot. This is why you can immediately fire the truck back up after you just turned it off, but if you wait a few minutes it just won't start.
Old Nov 24, 2016 | 03:28 PM
Marco Venegas
Excelent explanation !! Now I got it !! Thanks a lot !!
Adamristeen
Apr 14, 2016 07:25 PM
beechkingd
Aug 5, 2014 07:55 AM
The Carpathia
General Diesel Discussion
13
Nov 26, 2011 01:48 AM
mijale
Jun 6, 2007 09:24 PM
tmeyer68
Jun 23, 2002 10:07 PM
