Carb wont idle
Old Nov 21, 2016 | 07:55 PM
Harley Hill's Avatar
Harley Hill
Carb wont idle
So I have a 302 that I just put an air gap manifold and an edelbrock 1405 carburetor that I updated with an electric choke and throttle bracket. When I start my truck it starts right up, has a high idle then instantly drops idle speed and dies, even sometimes spitting through the carb. If I keep it running by giving it about half throttle it stays running and doesnt surge or anything but the second I bring the idle down just a little it will surge then die. Ive checked everywhere that I could have a vacuum leak and everything is plugged what could be the problem?
Old Nov 21, 2016 | 09:49 PM
RileyCarroll's Avatar
RileyCarroll
is your choke operating correctly? Have you tried using a vacuum gauge to tune the carburetor, if so, what did it say? Have you checked the timing and firing order after you swapped intakes
Old Nov 21, 2016 | 10:23 PM
Harley Hill
Im not sure on the choke, I dont have a vacuum guage, but the timing and firing order are perfect.
Old Nov 22, 2016 | 05:32 AM
Dave145's Avatar
Dave145
Carryover from your last thread, but what is the timing set to?
Is the carb new or used/rebuilt?
Spray brake clean around the carb an intake. If rpms go up or it stumbles, there's a vacuum leak.
Carbs need to be adjusted with a vacuum gauge. They're dirt cheap and invaluable. What is your idle speed set to?
Old Nov 22, 2016 | 11:04 AM
hurst1979olds's Avatar
hurst1979olds
A good base setting on the carburetor idle mixture screws is 2 1/2 turns from seated. Then adjust for max vacuum. But that initial adjustment will be enough where the engine will run and idle.
Old Nov 22, 2016 | 03:43 PM
RileyCarroll
Does it do this when the engine is hot or only when it's cold?
Old Nov 23, 2016 | 03:50 PM
Harley Hill
I turned my distributor all the way to the left and it runs now. It was all the time that it would do it
Old Nov 23, 2016 | 06:53 PM
Dave145's Avatar
Dave145
Do you have a timing light? What is your timing set to?
Your timing is most definitely off. Probably just by one tooth or so on the dizzy.
79BlueBetty
19
Sep 10, 2010 09:15 AM
brooklyn
Mar 14, 2010 10:15 PM
antunez13
Nov 13, 2007 02:05 PM
sfc11b
Jul 25, 2004 06:41 PM
DrFord
May 7, 2004 09:33 AM
