Sponsored by: Real Truck
Horn - How to replace it??
Old Nov 21, 2016 | 12:20 AM
Vijay's Avatar
Vijay
After much research (online), I find the horn on my 2000 SD is on the passenger side fender(top side). Well, how do I get to it? I need to replace mine as it has not worked in 10 years! Do I remove the panel itself? or can I get to it from fender well?
Any help is much appreciated.
Old Nov 21, 2016 | 10:26 AM
Trophy_23's Avatar
Trophy_23
I think the only real solution here is to add a train horn .
Old Nov 21, 2016 | 10:36 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I took out the fender liner to replace mine.
Old Nov 21, 2016 | 10:40 AM
HearseDriver's Avatar
HearseDriver
Not sure about a 2000, but on my 06 you have to remove the inner fender well. Not a difficult job but a little time consuming the first time.
Old Nov 21, 2016 | 03:11 PM
Vijay's Avatar
Vijay
That would be nice but I do not want to install a compressor etc.
Old Nov 21, 2016 | 03:13 PM
Vijay's Avatar
Vijay
Thanks guys. I will remove the inner fender well and give it a try.
Old Nov 21, 2016 | 08:40 PM
HearseDriver
You might also want to pick up a set of these trim & molding removal tools from Harbor Freight about $9.00. If I remember correctly there's a couple of those push in plastic jobs that also hold the inner fender in place.
Trim and Molding ? Discount Trim Tools ? Harbor Freight Tools
Old Nov 21, 2016 | 08:45 PM
Vijay's Avatar
Vijay
Thanks!!!
Old Nov 22, 2016 | 12:50 PM
HearseDriver
One other thought IF you haven't picked up your replacement horns yet. The HELLA 003399803 12V electric horns are supposed to be pretty Loud - I never cared for the wimpy sound of the factory horns in my 06. Unfortunately I didn't think about this until AFTER I had my inner fender well out & back in. The horns got pretty good reviews on Amazon. Just a thought.
https://www.amazon.com/b/ref=mm_1_ho...YWJ4WKWMJB7NS5
reddogracing
Dec 21, 2014 06:24 PM
bobiker
May 11, 2014 07:32 AM
leveltwo
Sep 30, 2009 07:38 PM
JetRooster
Dec 16, 2008 04:20 PM
62trvler
Jul 28, 2007 05:35 AM
