Hidden wiper motor
Old Nov 19, 2016 | 05:13 PM
chad77's Avatar
chad77
Hidden wiper motor
Has anyone used a hidden wiper motor kit from mid fifty? 56'
Old Nov 19, 2016 | 10:01 PM
56panelford's Avatar
56panelford
Not from Midfifty but yes I have.. in both builds.
Old Nov 20, 2016 | 08:36 AM
EBEAR's Avatar
EBEAR
May be I'm dreaming but was there not a thread some time ago about what a pia it was to install ?
Old Nov 20, 2016 | 09:00 AM
56panelford
I found it to be a very simple install, bolt it in and plug the harness together and provide power to the switch..
https://newportwipers.com/product/19...r/#wiper-motor
Old Nov 20, 2016 | 09:21 AM
EBEAR's Avatar
EBEAR
Good to hear as it is one of the huge amount of things I will need to do
Old Nov 20, 2016 | 09:39 AM
56panelford
I'll be installing mine as soon as I get this cab back on my frame some time in the next couple weeks..
Old Nov 20, 2016 | 09:52 AM
gerrymoe's Avatar
gerrymoe
May I ask a stupid question? To a person who has the stock complete electrical wiper equipment, what are the advantages of this, does it give you more room under dash, 56 year only, just curious as I have a 55 panel and have everything to use stock?
Old Nov 20, 2016 | 10:02 AM
56panelford
Really the only advantage was removing the motor off the firewall which was the main reason I did it on my panel because of the Chevy motors distributor interference. It is an easy install and some have wondered if it is noisy but it's no noisier than any new vehicle. Newport makes them for your year truck as well.. it does obviously take up a bit of room under the dash but does not interfere with anything..
Old Nov 20, 2016 | 10:17 AM
gerrymoe's Avatar
gerrymoe
Thanx John
I had forgot that the 56 wiper motor is on the engine side of the firewall.
53-55 has them on the inside, probably similar to what you are installing on the 56.
Old Nov 20, 2016 | 11:46 AM
EBEAR's Avatar
EBEAR
Ok that's even more info , mine is a 53 so I guess its on the inside anyway but will be 6 volt and still need to be changed . The joys of purchasing a project that had the cab stripped I'm sure I saw it in a box somewhere LOL .
Old Nov 20, 2016 | 12:35 PM
56panelford
Originally Posted by gerrymoe
Thanx John
Now I didn't know that about the 53-55's Gerry, I had a 53 and scrapped it and didn't pay that much attention to the differences..
Old Nov 20, 2016 | 01:01 PM
CharlieLed's Avatar
CharlieLed
I have used Raingear wipers (1956 Ford F-100 Trucks | RainGear Wiper Systems) on both slant cabs and my 56 F100. They are not cheap but unlike other "wiper motor replacements", this is a complete wiper system. Precision heim joints, lightweight tubular construction, 2-speed and intermittent control switch, and the capability to mount the motor on either side of the wiper system to accommodate other underdash equipment placement. Not cheap but well worth the $$$. BTW...this system is completely compatible with OEM underdash systems, including cowl vent and heater/ducting.
dthut
Apr 28, 2017 09:42 PM
55coe
Dec 17, 2013 12:49 PM
tip49
Jan 6, 2007 08:11 PM
PROSTOCK
Jan 21, 2006 11:58 AM
Green Streak
Electrical Systems/Wiring
Apr 1, 2005 11:09 PM
