Wiper motor
Old Dec 16, 2013 | 09:50 PM
55coe's Avatar
55coe
Wiper motor
I'm working on 1955 c600 and wiper motor doesn't work can these be rebuilt?
Old Dec 16, 2013 | 09:54 PM
bigwin56f100's Avatar
bigwin56f100
did you give it the 5-2 tune up?
5 hits with a 2 lb hammer, sometimes that's all they need
Old Dec 16, 2013 | 10:00 PM
55coe's Avatar
55coe
I haven't got to that point yet, I did get it out and what a pain that turned out to be. I did try to get it to run with a jumper wire to eliminate the switch but no luck.
Old Dec 16, 2013 | 10:16 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
If it is similar to the motors on the smaller trucks, you can use a late 80s - early 90s Cherokee wiper motor.
Go almost to the bottom of this article: Frequently Asked Questions (FAQs) on Adapting Major Components of 1948 to 1960 Ford Trucks .: Articles
Old Dec 17, 2013 | 12:20 PM
55coe's Avatar
55coe
Thanks, I went to article you suggested and it gave me all info I needed for using a newer motor. My problem is that my truck is still 6v. If I leave it 6v can I get the original motor rebuilt? I see new 6v motors for around $270.00, I just figured if its possible I would save a few bucks by rebuilding the old one. Maybe I should change the truck over to 12v, what's the big advantage to that?
Old Dec 17, 2013 | 12:33 PM
The Horvaths's Avatar
The Horvaths
Did you try cleansing/re-lubrication?
Old Dec 17, 2013 | 12:49 PM
raytasch's Avatar
raytasch
Believe Nothing
You just found one of the biggest reasons to convert to 12V, IMO. Cost and availability of 12V stuff is enough reason to convert unless you have a very original truck. $270.00 for a motor that can be had in 12V for much less? JMHO, others will vary. LIke BigWin said, give it a rap. Try pulling it apart, clean and oil.
RonKrem
Mar 11, 2016 10:56 PM
Pappys53
Aug 8, 2012 03:40 AM
Brewtl
Jul 10, 2010 06:32 PM
tip49
Jan 6, 2007 08:11 PM
19F10059
May 11, 2002 10:54 PM
