E250 side door bolt/pin problem
Old Nov 17, 2016 | 01:59 PM
Brad Bell's Avatar
Brad Bell
This new (to me) van (1985, E250 Super Cargo) has the double door entrance on the passenger side. The problem is that the rear door won't close all the way, because the pin, or bolt, on the bottom of the door, won't retract and therefore just bangs into the side of the strike plate. Trying to push it up manually, while moving the lever doesn't help at all.
Is this a familiar problem to anyone? any hints before I get started on taking the door apart?
Old Nov 17, 2016 | 05:27 PM
annaleigh's Avatar
annaleigh
Maybe this will help..I needed to look this up as mine rattles a little at the top of the door..
Old Nov 17, 2016 | 05:41 PM
annaleigh's Avatar
annaleigh
this might help too
Old Nov 18, 2016 | 04:13 PM
Brad Bell's Avatar
Brad Bell
I just took it to an RV place for a basic inspection, and the tech was nice enough to fix it for me! Said a part was bent.
Seems not unlikely that it could happen again, so thanks very much for the pics, they should come in handy! Did you scan those yourself or is the whole reference guide available somewhere?
Old Nov 18, 2016 | 04:25 PM
annaleigh's Avatar
annaleigh
glad you got it fixed. You can get the ford shop manual on CD here
FORD 1985 Bronco, Econoline E150-E350 & F150-F350 Pick Up Truck Shop Manual CD | eBay
I would also suggest a electrical, vacuum, trouble shooting manual too.
1985 Ford Factory Econoline EVTM Diagrams Manual
1985 Ford Factory Econoline EVTM Diagrams Manual | eBay
You might find them a little cheaper if you look around, I just did a search and through you the first one.. The shop manual on cd is a little hard to learn to use compared to paper books but is much cheaper..
I recommend both as they compliment each other
Old Nov 18, 2016 | 04:27 PM
annaleigh's Avatar
annaleigh
i have not had to use it yet, but i also bought one of these wiring diagrams
1985 Ford Econoline Van Wiring Diagram E150 E250 E350 Club Wagon Electrical | eBay
auto doug
2009 - 2014 F150
18
May 24, 2024 08:51 AM
Golden Helmet
Jan 15, 2017 10:50 AM
STLford
Aug 9, 2010 10:19 AM
95 F150 Dude
Aug 26, 2008 12:18 PM
Pastmaster
Sep 18, 1999 07:30 AM
