Hate slamming!
Old Sep 15, 1999 | 04:09 PM
Pastmaster's Avatar
Pastmaster
Hate slamming!
Does anyone know why I would have to slam the driver's door in order to shut it all the way? I think that I need to replace the Striker bolt. The rubber around the door is fine. The other door shuts correctly. Any ideas?
Old Sep 16, 1999 | 02:05 AM
Superdave's Avatar
Superdave
Hate slamming!
Are your door hinges wore out ,they could be letting your door drop down a little when you open it , then you have to slam it to get it ride back up over the striker bolt, to check them open the door a little bit , half way or less , or you may have to open it all the way up, some doors respond differently, grab ahold of the bottom of the door and lift up on the door, kinda rock it up and down this should show you slop in the hinges if you have any, you will feel it clunk . or have a helper watch them for play while your doing this.
Old Sep 16, 1999 | 03:47 PM
Pastmaster's Avatar
Pastmaster
Hate slamming!
>doing this.
Just a tad. I lifted from the bottom and kinda played with it awile and it appears to be slightly worn. what do you think?
Old Sep 16, 1999 | 11:05 PM
Superdave's Avatar
Superdave
Hate slamming!
Sounds like your door hinges are worn, it dosen't take much slop in your hinges to make the door not shut right. You can get down on the level of the door latch & striker bolt with a light and push the door up to the striker bolt slowly and look in there with your light and see where the latch is in relation to the striker bolt, then push the door on closed and feel if the door raises up to meet the striker, you may need to do this a few times to get the feel of things. A body shop can fix your hinges, or you can buy new ones (ouch) or you might find some good ones at a wrecking yard, but be sure to check them the same way. dont buy them if they are not still on the truck where you check them. good luck
Old Sep 17, 1999 | 07:51 PM
Pastmaster's Avatar
Pastmaster
Hate slamming!
SDave: I went over, like you said, the striker bolt and tried the door movement over again. its seems to be okay. would replacing the striker bolt do much?
Old Sep 17, 1999 | 08:40 PM
cody's Avatar
cody
Hate slamming!
I have the same problem on my passenger door, only its not my hinges. When you do slam it and its shut, the door itself is actually sunk into the body of the truck a little bit. can any one help..
Old Sep 18, 1999 | 07:30 AM
Allan Kidd
Guest
Posts: n/a
Hate slamming!
