No overdrive
if there is corrosion what should I do? and also you said from the PCM to the solenoid but my leads aren't long enough. should I just unplug the whole harness and ohm it from one end to the other.
You can fabricate a wire extension out of small gauge stranded wire. Small "test leads" with alligator clips (or just stripping the wire to allow you to shove the end of the small wire into the harness connector)enable you to connect the wire extension to the harness. Or you can buy or fabricate longer leads for your multimeter. Only one needs to be longer.
Using your meter in the same mode-resistance- check each wire with one meter lead touching ground and the other lead touching a wire. This will tell you if there is an accidental connection of that wire to the chassis ground from critter chewing or vibration. Then check for the resistance between one wire and the other wires in the harness to see if two or more wires are shorted to each other.
The test you already did was helpful because it shows that no wires are broken.
Larry
Larry
Larry
Larry
mcfad12
03-29-2004 07:43 PM
Ryan50hrl
07-09-2002 08:24 AM
