Sponsored by: Real Truck
Headlamp Side Markers Not Working
Old Nov 15, 2016 | 09:18 PM
jrwendell's Avatar
jrwendell
I recently installed LEDs on my 2011 Super Duty and also had the dealership turn off the build out indicator. Now I have noticed that the Headlamp Side markers are not working.
Has anyone ever seen this before? Searching the internet I have found no information.
Old Nov 16, 2016 | 08:00 AM
projectSHO89's Avatar
projectSHO89
All of the outside running (marker) lamps are on the same parallel circuit run off a single splice in the wiring harness. Do all of them still work, front and rear, including the license plate lights? Have you installed regular bulbs back into the missing lights to see if it's an issue with the particular LEDs you installed?
Hmm, what's a "build out indicator"? That's a new term for me.
Old Nov 16, 2016 | 11:12 AM
jrwendell's Avatar
jrwendell
Thank you for the response.
The light in question is the 194 build that is the side marker in each of the headlamp assemblies. It faces to the side of the vehicle.
The license place lamps work fine. I have not replaced them yet, find it odd that when I replaced the f/r turns with LED's these stoped working.
When a bulb goes out for the turn signals, it causes a hyper flash to let you know there is a buld out. I had the dealer disable this feature within the software. Other wise you have to put in a resistor and I did not want to as I have read other have problems with them.
Old Nov 16, 2016 | 12:35 PM
hoss66's Avatar
hoss66
I had the light out indicator turned off also and my side markers still work so that shouldn't be your problem
Old Nov 16, 2016 | 03:41 PM
projectSHO89
Thanks for the details. hoss66 is correct, the software change is irrelevant to the marker light issue.
I'd assume that the LEDs are either improperly installed or defective. Put the original bulbs back in to check.
Old Nov 16, 2016 | 03:58 PM
hoss66's Avatar
hoss66
Also did you replace the 194 bulbs with leds or just the turn signals?
Old Nov 16, 2016 | 07:42 PM
Chuck's First Ford's Avatar
Chuck's First Ford
if you are running normal 194.. they do not have a long life... I loose 2 or 3 every year.
Garth1516
Electrical Systems/Wiring
Jul 18, 2024 09:41 AM
87straightsix
Jan 13, 2013 02:23 PM
Dirk O
Nov 18, 2011 09:17 PM
califasbob
Jun 2, 2009 11:17 AM
FX4Jim3
2004 - 2008 F150
Jan 14, 2007 10:06 AM
