LED tail light Problem.
Old Jan 14, 2007 | 07:24 AM
FX4Jim3's Avatar
FX4Jim3
I recently purchesed both front turn and tail lights LED's Bulbs from Jusnes Mod.
The problem is the do not work, when installed w/resistors, or with out ( I tried it both ways) The dash lights flash when the turn signal are turned on.
The running light,s nor stop lights operate.
Has anyone else done this mod and it worked?
Am I missing something?
any Info would help.
Thanks
FX4Jim3
Old Jan 14, 2007 | 07:34 AM
Bob Jusnes's Avatar
Bob Jusnes
We have installed them before in quite a few applications, including an 04 F150. If the bulbs are not lighting at all, it sounds like you have their polarity incorrect.
LED bulbs can only be used in one direction, where and incandescent will work either way. Try spinning the bulb 180 degrees in the socket.
Old Jan 14, 2007 | 07:38 AM
Bob Jusnes's Avatar
Bob Jusnes
Also, make sure you are installing the resistors correctly. You will need one resistor per bulb, and use the tap connectors to bridge across the ground and the stop/turn (bright) circuit.
Old Jan 14, 2007 | 09:42 AM
FX4Jim3's Avatar
FX4Jim3
Thanks Bob
Disreguard the e-mail at the shop.
I got it to work, Didn't know they were one directional, Learn something new every day. Nice upgrade
Old Jan 14, 2007 | 10:06 AM
Bob Jusnes's Avatar
Bob Jusnes
Thats fine Jim, I'm just glad you got it to work. I need to get some GOOD directions for them. And feel free to contact me any time, through PMs or email here if you need help with something you got from me. Its not worth selling stuff and then forgetting about the customer!
51PanelMan
26
Feb 16, 2013 10:14 PM
Joeymt3
1983 - 2012 Ranger & B-Series
Nov 18, 2010 10:41 PM
Y2kXLTSport
Electrical Systems/Wiring
Nov 25, 2007 01:24 PM
jaym69
2004 - 2008 F150
Jul 14, 2007 06:25 PM
