New Member light problem
Old Jan 7, 2013 | 12:09 PM
87straightsix's Avatar
87straightsix
Question New Member light problem
Hi everybody!!
I recently purchased a 1987 reg cab f250 4x4 straight six 4-speed. I'm liking the truck so far and it is my fifth ford I have owned. I'm trying to figure out an electrical problem and was curious to see if anyone had any ideas. I have no front parking lights and no front turn signals. Headlights work fine and taillights all function as they should. I cut all the old trailer wiring out and made sure the stock wiring was all there. With the lights off, the front signals flash, but the parking light side of the light flash, not the bright side of the bulb. With the lights on, the same thing happens on the front, but they flash opposite of the rear lights. All fuses are In place and good and have new bulbs in the front sockets. I even unplugged the rear lights to make sure there was nothing interfering and still had the problem. Any ideas? Thanks in advance
Old Jan 9, 2013 | 09:31 AM
87straightsix
Question 2
I was thinking more about this as I need the front lights to work....would the turn signal switch make a malfunction like this or the headlight switch? It's only on the front of the truck so I am a little baffled.
I'm about to start chasing wires and about to hit the pick and pull for some different parts.
Old Jan 9, 2013 | 10:18 AM
White 97 xlt's Avatar
White 97 xlt
Check out the ground connection for the front lights..
The reason the turn signal is lighting the running light filament is there is no ground,,, The flashing opposite of the rear is another clue!!
Welcome to FTE!!!
Old Jan 13, 2013 | 02:23 PM
87straightsix
Welcome to FTE!!!
Sure enough. The ground terminal inside the light socket was rusted over. I tried to clean it and bend it back into place and it broke off. Next stop autozone for some new light sockets. Thank you so much for your help! I'm sure this wont be the last thing I ask about!!
03bigred2
Aug 19, 2018 04:54 PM
Dirk O
Nov 18, 2011 09:17 PM
cochran07
Jan 13, 2010 08:21 AM
1974oneton
Sep 15, 2009 06:44 PM
King_Midas
Electrical Systems/Wiring
Jan 14, 2006 04:41 PM
