window and door seals/gaskets
Old May 12, 2006 | 08:02 AM
76 F150 Ranger XLT's Avatar
76 F150 Ranger XLT
I am replacing both doors and painting the cab of my 1976 F150 2WD next month. I need to replace the glass runs in both doors and the door seals. I also need to replace the rear window gasket. I am planning on buying a complete gasket/seal kit that includes all the glass runs, door seals, and front and rear window gaskets. The problem is that my rear window is a factory split slider with what appears to be an aluminum frame and I cannot tell what gasket to get for the rear window. As far as I can tell, none of the catelogs mention gaskets for a split rear window. I think they describe the rear window gaskets as being for either a plastic frame or a black frame (not sure, I don't have them with me here at work). Does anyone know what gasket I should order for a factory aluminum frame split rear window?
Thanks,
Bob
Old May 12, 2006 | 08:06 AM
Bouts21's Avatar
Bouts21
On my Crew it's just a rubber gasket/seal that the window sits in then presses onto the edge of the window opening on the cab. I don't know where you looked, but LMC, JC Whitney, NPD may have something for you. Good luck.
Old May 12, 2006 | 08:53 AM
Mil1ion's Avatar
Mil1ion
Just click the BOTP logo just above your post and you can get you parts from a FTE 73-79 trucks forum...sponsor
Old May 12, 2006 | 04:54 PM
seneca's Avatar
seneca
Botp
I know I"m not all that bright but--what does BOTP mean?
Old May 12, 2006 | 08:08 PM
petes79f150's Avatar
petes79f150
Blue Oval Truck Parts- one of the fine FTE sponsors listed on the left of the screen.
Old May 13, 2006 | 12:06 AM
Mil1ion's Avatar
Mil1ion
I see a BOTP Logo hyperlink placed right in the middle of the page just above the initial post.
Don't you ?
Old May 13, 2006 | 04:35 PM
petes79f150
Dang, Dennis- good thing it wasn't a snake.......
deputydog03
1997 - 2003 F150
Mar 23, 2014 04:19 PM
boo-yaa138
Aug 30, 2013 01:11 PM
cujo8
Paint & Bodywork
Jan 31, 2008 08:53 PM
81-F-150-Explorer
16
Feb 7, 2007 12:00 PM
rjb03
Bronco II
Dec 6, 2005 06:52 PM
