Cool filter kit
Old Nov 6, 2016 | 02:09 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
Cool filter kit
Where does one get a Coolant filter kit and spend the least money yet get a good kit , serouly I am cheap but I want a decent cool set up, and suggestions?
Old Nov 6, 2016 | 05:05 PM
Bob_T's Avatar
Bob_T
My stock water pump had a lot of miles on it so I went ahead and got an IHC pump with a built in filter mount. I like it because there aren't any new hoses and connections. But it isn't completely plug and play, you have to remove some material from the housing with a hacksaw or some other cutting tool.
Old Nov 6, 2016 | 05:11 PM
PSU4ME's Avatar
PSU4ME
I just got one from diesel site. They all seem to be similar priced.
Old Nov 6, 2016 | 05:17 PM
Jaaaaaaackman
I not familiar with that IH pump, do you have a part# and source?
Old Nov 6, 2016 | 05:18 PM
Jaaaaaaackman
That's a nice clean install , I'll check that out.
Old Nov 7, 2016 | 07:51 AM
Bob_T's Avatar
Bob_T
Here is a pretty thorough thread on the IHC waterpump modification:
Navistar / IH Water Pump Upgrade - Diesel Forum - TheDieselStop.com
Here's where I got my pump. Note that I think they advertise it as the OEM manufacturer. I talked to the manufacturer and yes, they are the OEM manufacturer but this aftermarket pump has a cheaper seal in it than the one they sold to IHC. Mine has been working fine for 20,000 miles or so but you can get the real thing at an IHC dealer for a lot more money.
Water Pump - International 444E
Old Nov 8, 2016 | 02:20 PM
dclack's Avatar
dclack
Or you can just build your own kit with filters and a base from Fleet Filter...
https://www.ford-trucks.com/forums/1...l#post16095736
https://www.ford-trucks.com/forums/1...l#post16101913
Old Nov 13, 2016 | 11:52 AM
Black Helmet's Avatar
Black Helmet
Originally Posted by dclack
Looks like a great set up, especially the isolation valves - I bet those make for a fairly mess free filter swap!
Old Nov 13, 2016 | 12:23 PM
madMatador78's Avatar
madMatador78
Napa alsof makes a kit. Part number 4019 I believe. That's the setup I'm running. Only thing I would suggest is the shut off valves.
Old Nov 14, 2016 | 01:48 PM
dclack's Avatar
dclack
Originally Posted by madMatador78
Napa also makes a kit. Part number 4019 I believe. That's the setup I'm running. Only thing I would suggest is the shut off valves.
That's the same filter base that Fleet Filter sells for about half the price.
Old Nov 14, 2016 | 03:29 PM
lee00's Avatar
lee00
That's an interesting mounting location...never thought of over there...
Old Nov 14, 2016 | 05:01 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Doesn't interfere with ic pipes there
Old Nov 14, 2016 | 05:15 PM
madMatador78
That mount was born of an accident. I bent it the wrong way (expert fabricator here after all) and was upset. Then I put it up there and saw that and thought it would work better. I did have to bend it a bit after it had a couple run ins with the fan. Thankfully it didn't puncture the filter. It's been on there since 2014 and no issues.
I've been told that it may interfere. I'm not sure yet. Hopefully soon I'll be finding out. If I could ever start gathering parts. I may not need it as the new motor came with a IH Bus water pump with built in filter.
Old Nov 17, 2016 | 12:44 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Here in the 2 post is my installation in similar position and doesnt interfere with the ic pipes
https://www.ford-trucks.com/forums/1...hroud-mod.html
Leemakesmepee
24
Jun 19, 2013 08:04 AM
JT250
20
Apr 3, 2012 07:03 PM
mind
Aug 24, 2009 05:49 PM
mjlewis
13
Nov 13, 2006 01:44 PM
